2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Help w M6 Muffler Install on 550i xdrive
      11-04-2017, 08:29 PM   #1
davis944s2
Drives: 2014 550i xdrive
I thought it was a straightforward mod to install M6 mufflers on my 550i xdrive, but my (trusted) indy mechanic says the geometry/layout is all off and is a "waste of time." Can those of you who have done this give me some advice?
I thought that, if the 550 exhaust is cut off close to the mufflers, the M6 mufflers can drop right in (or close). Any advice is appreciated!
Looking to get this done in NJ/NYC area (too, if any recommendations).
Thanks in advance!!
      11-04-2017, 11:26 PM   #2
ey2001
ey2001's Avatar
310
Drives: F10 535i 6spd
You need to take it to a muffler shop... they need to redo/extend the hanger and do the axle piping...
      11-05-2017, 05:34 AM   #3
AldoNY
Drives: 2014 550i x drive
Thanks in advance!!
I had the same issue too, it wasn't just a drop in method. Went to a trusted shop in Westchester and said, it more in depth, have to make a bunch of adjustments, my M5 exhaust was also cut close to the muffler, so he basically had to weld on a steel section of pipe to align it.
      11-06-2017, 08:10 PM   #4
davis944s2
Thanks. Found a couple of recommended muffler shops. Will take the mufflers there and see what we can sort out. Any additional experiences or recommendations are appreciated. Thanks, guys.
      12-09-2017, 01:34 PM   #5
davis944s2
I found a solid muffler shop that was able to install the M5/M6 mufflers on my 550.
Only wrinkle is -- they did not have vacuum lines in stock long enough to reconnect the exhaust valves/flaps, so I am stuck in closed position.
Can anyone show me where I need to connect from and too to get the flaps reconnected? I have vacuum hose coming in soon.
Any advice is appreciated. Thanks
      12-09-2017, 02:23 PM   #6
Creynolds
Drives: 550i
This is where the vacuume lines connect
      12-10-2017, 07:32 PM   #7
davis944s2
I found the hose run. Got it sorted out. Thanks.
