2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding LED Fogs / Reverse Malfunction Even After Coding
      12-01-2015, 10:13 PM   #1
KryptosXLayer2
38 57 6.5, -77 8 44
KryptosXLayer2's Avatar
Drives: 2020 X3M Competition
2013 BMW 550i  [0.00]
It seems we're having an issue coding my F10 to play nice with LED H8 fog lights and LED 921 reverse lights. I just sent back the last "CanBus friendly error-free" fogs and will be upgrading to a brighter set with a separate error-free load resistor adapter. I'm not sure if that's going to work with the coding done to the fogs already, I can't put an in-line adapter in place for the reverse lights due to their mounting location, and I don't know what the codes were that were meant for the fog lights, but the reverse lights are also showing a malfunction on the dash.
Can anyone who has successfully installed aftermarket fogs and reverse lights tell me what the proper code is to stop cold and warm checks through CanBus? I had a code I thought would work but it was for an F30. I'm not the coder nor do I have any input when it comes to this, but if I can find the correct code necessary for those who have used non "CanBus friendly error-free" bulbs and got them to code-out without showing any malfunctions, I can provide that to the shop doing the coding for me.
Thanks in advance! Lots more coding questions incoming but will ask those separately after searching to see if the answers are already here - tried that with this but couldn't find any solid answers....
BETWEEN SUBTLE SHADING
AND THE ABSENCE OF LIGHT
LIES THE NUANCE OF IQLUSION
      12-05-2015, 11:08 AM   #2
KryptosXLayer2
38 57 6.5, -77 8 44
Everyone has working LED fogs and reverse lights? No help with my situation?
      12-12-2015, 08:44 AM   #3
DonJkZ
Drives: 520d
Not sure about LED fog lights, but I know that there are error free reverse lights out there
      12-12-2015, 08:47 AM   #4
KryptosXLayer2
38 57 6.5, -77 8 44
The ones I purchased were advertised as "CanBus Error Free," still showing an error. I got the fog lights straightened out either through coding, buying a different set of bulbs, or a combination of the two, but I still can't get the error to go away for the reverse lights.
I bought resistors for the fogs but they haven't even arrived yet! They worked without them, and I can't put in resistors for reverse lights with the limited room and mounting location of the bulbs in the harness, so I guess I have to keep trying to find true "error free" reverse lights until I find one that actually works....
      12-12-2015, 09:19 AM   #5
DonJkZ
Drives: 520d
Ahh I see, just to confirm...is the error thrown up on the dash? because the reverse lights I have give me no errors? unless I am missing the errors somehow?
      12-12-2015, 09:57 AM   #6
KryptosXLayer2
38 57 6.5, -77 8 44
Yes, the orange triangle on the bottom left of the cluster and then under Vehicle Info on the Nav screen shows the error.
      12-12-2015, 10:27 AM   #7
DonJkZ
Drives: 520d
Okay, well if your front fogs are now fine, you could try buying the reverse lights I have? They work fine for me, not sure if I'm allowed to post eBay links here?
      12-12-2015, 07:35 PM   #8
cm048
Drives: BMW F10
For the front fog lamp I would suggest;
Quite expensive, original from BMW, around $180 each.
It required a coding at module FRM3090. Compare to bulb retrofit, it is not only beautiful but also actually works with proper light pattern.
      12-12-2015, 11:26 PM   #9
KryptosXLayer2
38 57 6.5, -77 8 44
You can PM me if you think that would be better
Damn.... I was interested in those but read somewhere they were way more expensive than that, so I gave up looking into part numbers! That's much better than what I thought they were. I'll get those after I put in more go-fast parts in a few months, thanks for the suggestion!
      03-09-2016, 02:15 PM   #10
samy_1985
Drives: BMW 5 series F10
ebay Item: 172080831553
for fogs I bought a kit with resistors included. eBay item number:172032326882
these are 7.5W is not a bright white... if you can find 35W are better.
for more DIY for F10 model join this group: BMW 5 Series (F10) UK
      03-09-2016, 08:53 PM   #11
DaHeadlightGuy
Drives: 2013 DSB F10
Reverse Coding is
FRM
AUSG_25_RFS_R_IS_LED to aktiv
AUSG_24_RFS_L_IS_LED to aktiv
      03-11-2016, 02:43 PM   #12
jabbarjd
jabbarjd's Avatar
Drives: 2019 BMW X7 xDrive50i
Originally Posted by DaHeadlightGuy View Post
Reverse Coding is
FRM
This worked for me when coding my reverse LEDs. No resistors necessary.
Relatedly, I have an F10 M Sport pre-LCI and I've read that the fog lights take H11 bulbs. 2 questions:
  1. Does anyone have a link to bulbs they bought and liked? and
  2. Does anyone know what needs to be coded for the LED fogs?
I want to match the color as closely as possible to my xenon headlights and DRLs, and really don't want the bulbs looking blue. For the coding, I'm just looking for something like the above-quoted information. Thanks.
2019 BMW x7 xDrive50i in Phytonic Blue on Black -- 22" 756 Wheels
2015 BMW x5 xDrive35i in Mineral White on Canberra Beige - (sold)
2013 BMW 535i M Sport in Titanium Silver on Black - (sold)
1999 BMW z3 2.3 in Space Gray on Black - (sold)
      03-13-2016, 11:54 AM   #13
Aaron@Autosource
Aaron@Autosource's Avatar
98
Drives: F110/F22
PreLCI MSPort Fogs, H11 35W HID Works with capacitors, no coding needed
PreLCI Reverse Bulbs, I Used Generic R5 LED, no thing else, no coding needed
LCI Msport Fogs, ditching the LED oem set and going HID/projector soon, LED ones are for sale.
LCI Reverse Bulbs, H21W(socket Bay9S), or change the socket over to whatever you want, T10/T20 etc. Installed with 6ohm 50W resistors on each, no error, no coding required. I believe the same applies to PY24W front signals on LCI models.
PS H8 & H11 are basically interchangeable.
      03-14-2016, 11:57 AM   #14
jabbarjd
jabbarjd's Avatar
How did you manage to install the reverse bulbs without capacitors or coding? I got a bulb out warning when I installed them and wanted to check if they were "error free."
I wish I could afford an LCI F10 with all the options I want. Then I'd have the right fog lights (and adaptive LED headlights).
      03-14-2016, 01:23 PM   #15
Aaron@Autosource
98
Drives: F110/F22
I couldnt afford the adaptive LED lol-
These are the ones I got for my prelci:
http://store.ijdmtoy.com/Plasma-High...s-p/10-326.htm
      03-16-2016, 11:36 AM   #16
jabbarjd
jabbarjd's Avatar
I bought the exact same bulbs for my reverse bulbs! Mine threw bulb out warnings though, so I coded the reverse bulbs.
Do you have a link to the fog light bulbs you bought?
      03-16-2016, 07:27 PM   #17
Aaron@Autosource
98
Drives: F110/F22
Any generic 35W HID would work, just need to do this:
http://www.e90post.com/forums/showthread.php?t=338009
      03-17-2016, 02:10 PM   #18
jabbarjd
jabbarjd's Avatar
AWESOME, I can do that! Thanks!
      03-17-2016, 03:08 PM   #19
Aaron@Autosource
98
Drives: F110/F22
Actually, PM me your address, I have some premade ones I wanna test out, but since I no longer have the preLCI I dont have one to test on. Did you already purchase your HID kit as well?
      03-17-2016, 03:58 PM   #20
jabbarjd
jabbarjd's Avatar
PM sent
And no, haven't purchased the HID kit yet.
