2010 2011 BMW 5 Series Forum F10 535i F10 steering rack cables |
10-04-2019, 09:34 AM | #1 |
Rep 5
Hi guys.
Does anyone here own a 535i F10 (year 2010) with power steering that can take and send me pictures of the data cable and connectors that reach the power steering box? I explain: The handle of mine grabbed something on the road and was torn off, carrying the black engine cover of the box. I already bought a new box but I can't get the data cable. It is a cable with a 6-pin connector but only 3 are used. I need to know exactly which pins of this connector are used and the order of the cables. Or someone who knows the code of this cable because it is able to replace it. Thank you in advance. |
10-06-2019, 11:41 AM | #3 |
Rep 7,548
Have you tried using the online TIS website? It should be able to give the pin-out of the wiring connector. You can click the link below and type in the last 7 digits of your VIN and then type a key word or phrase (like "power steering box") into the search box to get some results to select through...or you can go directly to the wiring diagram and try to find it on your own: www.newtis.info
Some tips if you're unfamiliar with the site:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
10-07-2019, 11:15 AM | #4 |
Rep 5
10-07-2019, 11:57 AM | #5 | |
Rep 5
10-07-2019, 01:19 PM | #6 | |
Rep 5
I FOUND IT!!! Thank you, this site had everything. |
EL Jeffe 5612.50 |
