2010 2011 BMW 5 Series Forum F10 F10 2019-1 Nav Update DIY |
11-16-2018, 05:31 PM | #1 |
Rep 639
Let me start off by saying that this is my first DIY here, so if you have any constructive criticism, I am all ears. Also, just to put it out there, I am in no way affiliated with the creators of any of the software mentioned here, and I am by no means an "expert" with using any of them. If you search online I'm sure you can find where to download all the software needed and how to install it properly on your PC.
Everything I did to get this to work was done using Windows 10 running in BootCamp on my MacBook Air. So, after much research, I really couldn't find a complete "dummy-proof" guide explaining exactly how to update to the latest maps while generating my own FSC code for the install. I ended up using multiple sources and a lot of trial and error to figure it out all out. It seems to be a pretty simple task if you're wiling to pay for an FSC code. I had some free time and wanted to see if I could do it without buying one. In the end I ended up succeeding! The basics for install can be found in multiple places online and include the following: 1. Download latest map data for your specific nav unit (Mine is a Next NBT) 2. Extract files to a blank USB drive that is formatted as FAT32 3. Insert USB stick into car, and wait for prompt to update from USB 4. Enter FSC code That's where the research and trial and error came in. For those of you that don't know, the FSC code is specific to the map update and your cars VIN. This code can be bought online, or if you don't mind spending some extra time using Esys and some other software that can be found online, can be generated for free. I ended up following the various guides online to get the first half of what I needed using Esys. None of the guides I found online were really much of a "guide for dummies", or at least none that I found seemed to be written that way. They all seemed to be written as if you really know your way around Esys and Windows command prompt. I used BMW Esys, BMW-FSC-NBT, and Base64 (Which came with my download of BMW-FSC-NBT). Here is my version of the steps necessary to create the first half of what you need using Esys: 1. Connect to car with Esys. 2. Click “FSC Extended” on left of Esys. 3. Enter “0x63” for the “Diagnostic Address”. 4. Click “Identify”. 5. Wait for “Base Variant” to display your cars' info. 6. Enter “0xDE” for “Application ID”. 7. Enter “0x1” for “Upgrade Index”. 8. Scroll down and select “StoreFSC”. 9. Select the “ >> ” button. 10. Click “Read”. 11. Click “Save” and save as last 7 digits of VIN.FSC (example: XXXXXXX.FSC) So that's the part that Esys takes care of. After this, I used a program called Base64, which came with the BMW-FSC-NBT software download I used in the next section. This step requires you to open a command prompt in Windows. 1. Make sure you have the BMW-FSC-NBT software installed and know the location. 2. Move the file you just saved with Esys to the "tools" folder inside the BMW-FSC-NBT software folder. 3. Open a command prompt Windows by typing "cmd" into the start menu on your computer. Now you need to navigate to the “tools” folder you just moved the FSC file to. You need to type "cd" then a space, then the location of the "tools" folder into the command prompt window. (Example: "cd C:\Users\YourName\Applications\BMW-FSC-NBT\tools") 4. Now in the command prompt window, type in the following using YOUR FSC file name and last 7 digits of VIN (Replace the Xs with your VIN) “Base64 XXXXXXX.FSC XXXXXXX_000DE001.FSC” 5. Run the BMW-FSC-NBT software by clicking it. 6. Select your newly made FSC file by clicking “Browse” and selecting the new file that you just created in the “tools” folder. 7. Select the correct map from the selection. 8. Click “Generate”. (This will generate your FSC code to enter into iDrive) The issue I had here is that the map I was trying to update to (North America Next 2019-1) wasn't shown in the list! I had read that I needed to update my lookup.xml file to reflect this map, but didn't quite understand how to do so properly. These are the steps I used to update it to allow me to select it in the BMW-FSC-NBT software: 1. Navigate to the “tools” folder of the BMW-FSC-NBT software. 2. Right click, then select “edit” on the “index.xml” file. 3. Scroll down to the most recent map update for your application. (Mine was showing North America Next 2014-2 as the most recent) 4. Copy the lines from the most recent map update and paste below it. 5. Change “id” to match the map data file name. 6. Change the last two characters of “FscShort” to “FF”. 7. Change “name” to reflect the map data you are updating to. 8. Change “sop” to yesterdays' date. EXAMPLE for North America Next 2019-1 (Changes I have made are in RED) </SgbmId> <SgbmId id="NAVD_000014B8_255_004_177" SWID_FscShort="00A800FF" name="Road Map NORTH AMERICA Next 2019-1" supplier="TAS" sop="11.01.2018" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="NBT-HB" Format="CIC" /> <SwUpdate SwUpdateEntry=""/> </SgbmId> Once I finally completed the changes, the list showed the "North America Next 2019-1" map. I selected it, then hit "Generate". This produced my FSC code needed to install the update! Finally! I then plugged my USB drive with my map data on it into the car, selected "Update" in iDrive when prompted, and then entered this newly generated FSC code. It took about 15 minutes, then I had a message of success in iDrive! Recap of the Steps: VERY FIRST STEP: Download and install BMW Esys and BMW-FSC-NBT and make sure you have Base64 within your BMW-FSC-NBT software folder. Download Map and ready USB Drive: 1. Download latest Maps for your vehicle. Unzip and place on newly formatted FAT32 USB Drive. Updating the lookup file (If your map isn't on the list in BMW-FSC-NBT): 1. Navigate to the “tools” folder of the BMW-FSC-NBT software 2. Right click, then select “edit” on the “index.xml” file 3. Scroll down to the most recent map update for your application 4. Copy the lines from the most recent map update and paste below 5. Change “id” to match the map data file name 6. Change the last two characters of “FscShort” to “FF” 7. Change “name” to reflect the map data you are updating to 8. Change “sop” to yesterday EXAMPLE for North America Next 2019-1 (Changes in RED) </SgbmId> <SgbmId id="NAVD_000014B8_255_004_177" SWID_FscShort="00A800FF" name="Road Map NORTH AMERICA Next 2019-1" supplier="TAS" sop="11.01.2018" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="NBT-HB" Format="CIC" /> <SwUpdate SwUpdateEntry=""/> </SgbmId> Generating an FSC code: 1. Connect to car with Esys 2. Click “FSC Extended” on left of Esys 3. Enter “0x63” for the “Diagnostic Address” 4. Click “Identify” 5. Wait for “Base Variant” to simply the cars’ info 6. Enter “0xDE” for “Application ID” 7. Enter “0x1” for “Upgrade Index” 8. Scroll down and select “StoreFSC” 9. Select the “ >> ” button 10. Click “Read” 11. Click “Save” and save as last 7 digits of VIN.FSC in the “tools” folder of the BMW-FSC-NBT software folder (example: XXXXXXX.FSC) 12. Open command prompt and navigate to the “tools” folder you just saved the FSC file in (Example: "cd C:\Users\YourName\Applications\BMW-FSC-NBT\tools") 13. Type in the following using YOUR last 7 digits of VIN “Base64 XXXXXXX.FSC XXXXXXX_000DE001.FSC” 14. Run the BMW-FSC-NBT software 15. Select your newly made FSC file by clicking “Browse” and selecting the new file in the “tools” folder 16. Select the map from the selection 17. Click “Generate” (This will generate your FSC code to enter into iDrive shortly) 18. Plug in the USB stick with the maps data into the car, wait for the update prompt, then select update 19. Enter the FSC code you generated when iDrive prompts you I hope this helps someone out there who is struggling to update their car to newer maps. |
9
12-10-2018, 11:32 PM | #3 |
Rep 808
I will try this out and update you as I've been wanting to update my maps for the longest time but couldn't justify paying the dealer or some novice remote coder hundreds of dollars.
12-13-2018, 01:41 PM | #4 | |
Rep 27
12-13-2018, 02:13 PM | #5 |
Rep 639
Mine is a 2015 535 with NEXT NBT. I’d image it would work with any Nav unit, just make sure you have the correct map update, as in I needed the NEXT update as my head unit is the NEXT NBT, but if you have the Premium Nav, you need the Premium map update.
12-16-2018, 08:06 PM | #8 |
Rep 5,389
BimmerOwner45.50 |
12-16-2018, 08:09 PM | #9 | |
Rep 86
It will be here by Friday. Thank you for the tip. 👍👍 |
12-25-2018, 02:16 PM | #10 | |
Rep 7
CIC will require 4 x 8Gb(Min) USBs (FAT32) to load the map data from the glove box USB port. *Some versions can be done on 1 flash drive. Depending on the source. NEXT can be loaded from a single 32Gb USB (FAT32/Can also try NTFS) through the USB port in the center console. For FSC codes, easiest to just buy the lifetime code on eBay ($15-$25) You DONT need esys or any other software - maps can be updated through Idrive. ***Unless some drastic change was done with 2019 maps, Im only up to 2018. Last edited by samadkins29; 12-25-2018 at 02:37 PM.. |
12-25-2018, 03:42 PM | #11 | |
Rep 5,389
I had no problems installing the 2019-1 map into our 2014. |
12-26-2018, 09:45 AM | #12 |
Rep 7
Premium only has up to 2019, NEXT has 2019-1. The data on the map itself might be very close, but its not the same map data files.
12-29-2018, 10:29 AM | #13 | |
Rep 697
Drives: 2013 535xi
Cheers.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension 2000 528i, Cosmo Black, beige interior, Sport package (retired) |
12-29-2018, 11:24 AM | #14 |
Rep 14
Oil cooler oil housing stripped bolt !!!
How can I go about fixing this ? Anyone know the size for helicoil or timesert [IMG][/IMG]
Any help gladly appreciate it |
05-20-2019, 03:00 PM | #15 |
Rep 17
@swflf10
Thanks for your post. Here's an update to help others on the back of your post. My car is an F10 with a HU_CHAMP2 using the MOVE maps. I did have Road Maps Europe 2014-1 but now have 2018-2. I created my FSC file from Esys by using this guide and have repeated the steps below for anyone with the same head unit as me. You will need esys and basic esys knowledge to do this. If you don't, the information is easily accessable. In addition, I downloaded 2018 maps that somone posted on the net. Again, can be found through the power of Google. Finally, I used the bmw_cic_fsc_generator Anyway here's what I did On esys: 1. Connect to car with Esys. 2. Click “FSC Extended” on left of Esys. 3. Enter “0x63” for the “Diagnostic Address”. 4. Click “Identify”. 5. Wait for “Base Variant” to display your cars' info. 6. Enter “0x1B” for “Application ID”. Mine is a HU_CHAMP2. Nbt will be different 7. Enter “0x1” for “Upgrade Index”. 8. Scroll down and select “StoreFSC”. 9. Select the “ >> ” button. 10. Click “Read”. 11. Click “Save” and save as last 7 digits of VIN.FSC (example: XXXXXXX.FSC) on laptop. Make a note of where you saved the file. Then over to your laptop. Using the bmw_cic_fsc_generator: Download and run bmw_cic_fsc_generator-win32-1.9. This is the link I used https://f30.bimmerpost.com/forums/sh....php?t=1456836 When you run the generator for the first time, you'll need to close and reopen it. 1. In open file, select the file you generated from esys. 2. In Map type, I selected MOVE 3. In region, mine is Europe 4. In Maps I selected the map map that I had downloaded. (Road map Europe move 2018-2 5. Then I simply generated the code. Prepare USB: 1. COPY map files onto a a fat32 USB. 2. Plug into glove box USB. Again this is on the F10 3. Follow instructions and enter map code generated. 4. Wait for the magic to happen. Takes approx 1 hour to install Credit to all you geniuses on these forums! |
12-30-2021, 04:03 PM | #16 | |
Rep 7
02-10-2022, 01:26 PM | #17 |
aa240sx
15
Rep 21
Just wanted to say this method is definitely outdated. I can confirm that the method below is far superior, more efficient, and works.
I'm not a programmer or coding expert, but instead of having to input hex codes, etc, you just use a 1b.zip file on a usb drive, put it in your f10, then take the resulting files and put that in fsc generator and voila, you get your fsc code. that and your maps gets you updated. Again, this worked for me. https://www.e90post.com/forums/showthread.php?t=1461515
2012 F10 535i Msport - Sophisto Metallic
2003 E46 M3 6speed (converted) - Alpine White |
02-10-2022, 09:50 PM | #18 | |
Rep 5,389
05-02-2022, 08:12 PM | #20 |
Rep 103
NAV Update
I would really like to do this but I don't have a clue as to what you guys are talking about. Does anyone have an update for sale? My car is a 2011 F10 535iX Drive with M. Most of the time my car shows me either in a field or in the middle of a river.
05-02-2022, 11:42 PM | #21 | |
Rep 5,389
If I can do it, anyone can! |
12-23-2022, 11:24 AM | #22 | |
Rep 11
I've a question regarding getting FSC from the car. Did you used E-Sys direct or you opened E-Sys via another software like Launcher(E-Sys Launcher PRO or E-Sys Launcher Premium) or BimmerUtility? As far as I know, for FDL Coding E-Sys requires a 3rd Party “Mapping” application such as E-Sys Launcher PRO(or BimmerUtility) as it Provides CAFD Mapping but I'm not sure if this 3rd Party “Mapping” application is also needed for getting FSC from the car. |
