2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Navigation Unit Restart?
      02-01-2017, 03:59 PM   #1
doublemetreF10
doublemetreF10's Avatar
Drives: '13 F10 535xi N55
Not sure what to call it, but the center screen (navigation) completely shut off and restarted on me today about 4.5 hours into a 5 hour drive.
Just after I switched audio sources from my iPod under the center console armrest to bluetooth audio from my iPhone and it just went blank, and everything restarted. the "BMW Connected Drive" graphic was displayed and then it informed me that my route guidance was interrupted and asked me if I'd like to resume route guidance.
It was a minor inconvenience, and everything seems to be working as it should now, but it's giving me some concern.
Is the occasional restart like that "within normal limits" of operation, or should I ask the dealer about it whenever I'm there next?
TO SEE THE WORLD, THINGS DANGEROUS TO COME TO, TO SEE BEHIND WALLS, TO DRAW CLOSER,
TO FIND EACH OTHER AND TO FEEL. THAT IS THE PURPOSE OF LIFE.
      02-01-2017, 05:22 PM   #2
wcr3d
Drives: 2013 535i XDrive M Sport
It is called "IDrive", yours should be the NBT version. No it is not common. I would mention it on your next visit.
      02-01-2017, 11:36 PM   #3
xxpanipuri
Drives: 550i
i've had a similar issue recently...just started in the past few months (had the car about a year now) going to bring it up with my Service Advisor when it goes in for an oil change in March...
      02-02-2017, 04:15 AM   #4
khai Dow
Drives: "Grey Goose" X7 40D, IOMG M4C
I've had a very occasional restart - for me it seems to happen if Im connected via USB to the iPhone and am using the BMW Connected app. More often is when I do a force restart of the iDrive because I'm having trouble with either the bluetooth connectivity or can't get it to play music properly on the phone.
You can do a restart by holding down the on/off switch on the dash for around 30s.
      02-02-2017, 04:16 AM   #5
skipsmith
Drives: 520 D M Sport
It happened to me a couple of times last year, like you after about 2 hours driving, took it to the dealer and they said there were no fault codes and to keep an eye on it, since then it hasn't happened but I havnt driven for that length of time
      02-02-2017, 05:00 AM   #6
doublemetreF10
Thanks for the replies everyone.
I often have anywhere from 2-8 hr drives to and from client locations, so if this issue only occurs during longer drives, I will get a fair amount of repeatability.
I have a 5.5 hour drive home tomorrow, and then another 2 hour round trip on Saturday.
      02-02-2017, 08:05 AM   #7
claykin
Drives: various BMW
What is build month/year of car?
What version firmware is on your iDrive?
to check firmware version do the following:
1. Start car
2. Click Nav button on console controller.
3. Click iDrive controller right to the Options screen.
4. scroll down to Navigation System Version.
4. Last line will show this info.
2023 840GC | 2021 740i | 2019 X3
      02-02-2017, 08:07 AM   #8
doublemetreF10
1. Start car
It's a 12/2012 build car, I'll post the requested information when I'm back in the car.
      02-02-2017, 10:56 AM   #9
xxpanipuri
Drives: 550i
you can also download and upgrade the firmware from bmw's website.
you just need the last 7 of your vin...
http://www.bmw.com/com/en/owners/con...re_update.html
      02-02-2017, 11:03 AM   #10
doublemetreF10
This is my iDrive navigation version.
      02-02-2017, 12:22 PM   #11
ThaiBruin
ThaiBruin's Avatar
Drives: F10 535i M-Sport
this happens to me once in awhile too. I think it has something to do with my bluetooth connection with my Galaxy S7. Whenever I try to use bluetooth audio or even bluetooth calls, the connection drops and keeps trying to reconnect. Sometimes it'll be stable on some drives, and others it won't stay connected. On some occassions, the iDrive will just completely restart, sometimes 2 or 3 times during a 30 minute drive.
I'll try updating the software to see if that helps.
Retired- 2013 MG 328i Sport Line 6MT - BMS Stage 1 / M Performance exhaust / M Performance steering wheel / M Performance shift knob/boot
      02-06-2017, 03:00 AM   #12
makeapullup
Drives: F11 535d
I too have had this issue for a while. First used an Apple Iphone 6 without issue. (At least not that I noticed) Switched to Samsung S7. On bluetooth (audio and tel) it almost always resets after 20 minutes. As I normally only drive about 30 minutes i'm not sure if it would happen again after the next 20 mins.
The dealer found no errors and reloaded the cars software. Problem still the same.
I have tried many variations, it seems its the Bluetooth Telephone that is giving the problem. On audio bluetooth it doesn't switch off.
BMW dealer says only option is to replace the idrive system! About EUR1600.
For now i'm not using the blutooth and hoping for an update or a cheaper solution...
      02-09-2017, 09:56 PM   #13
ThaiBruin
ThaiBruin's Avatar
I've tried to update my bluetooth/comm software, but something is amiss. When I go to the bmw.com/update site, the available software shown is for MN-002.xxx and TN-002.xxx which seem like files that are older than what I already have on my car.
However, in my car it shows the current versions as:
Media: MN-003.011.002
Phone: MN-003.011.002
When I attempt to load the update file from a USB drive, i get a message saying that the software on my usb drive is not compatible.
Anyone else experience this?
      02-11-2017, 12:13 PM   #14
ruben356
Drives: F13 M6 _ San Marino Blue
I have had the same thing happen with the Bluetooth connection drop out not the entire unit though. Could this be making the unit crash possibly and it is soft booting the unit? Thanks for the link on the upgrade database was looking for that for a while now.
