2010 2011 BMW 5 Series Forum F10 pre lci LED bulb? what type? |
10-13-2020, 01:38 PM | #1 |
Rep 97
so i have a 2013 528i pre lci and wanting to upgrade my bulbs to led. saw it on the internet but im not sure about it which one is mine.
can anyone tell me whats the bulb type for low beam and high beam and fog light? and maybe can give me a recommendation from amazon? much appreciate it. |
10-13-2020, 04:58 PM | #4 |
Rep 2,591
High/low beams:
Halogen - H7 Xenon - D1S Fog lights - H8 for base, H11 for m sport. So in your case, H8 Just a reminder that non-LED housings aren't designed for LED bulbs, so you will likely be blinding other drivers if you swap to LED high/low bulbs. Addtionally, you'll need to make sure the LED has the proper resistor to prevent flashing on start up (and throwing a code), or just code out start up bulb check.
2015 BMW 535xi
10-14-2020, 07:55 AM | #5 | |
Rep 915
Instgram @burninja
