2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Engine Coolant too low on F10 2010
      11-12-2020, 01:00 PM   #1
t4ure4n
Drives: 2016 BMW X3 xdrive 20d
Question Engine Coolant too low on F10 2010
I have a 2010 model 520d F10. The car hasn't been driven for a long time and today I was checking it to make sure that everything is fine.
And what i found is that the coolant level in the reservoir has fallen well below the min sign. I can't even see any liquid in it. So I want to refill it but i don't know what is the recommended coolant for this car.
Can someone please advise me what type and quantity of coolant shall I buy?
Edit 13/11/2020. I should also add that the reason I started checking things was because the heaters & demister would NOT stay on i.e when I start them they start blowing air but after just a minute or so they automatically stop working even though the lights on the display stayed ON.
      11-12-2020, 01:51 PM   #2
Hoa
Coolant doesn't just disappear so if it's low, something is slowly leaking. For now, just add distilled water to fill it up and keep an eye on it.
      11-12-2020, 10:49 PM   #3
Unspec
Unspec's Avatar
1300
Drives: 2015 BMW 535xi
Originally Posted by t4ure4n View Post
I have a 2010 model 520d F10. The car hasn't been driven for a long time and today I checking it to make sure that everything is fine.
And what i found is that the engine coolant reservoir has faleen well below the min sign. I can't see any liquid in it.
So I want to refill it but i don't know what is the recommended coolant for this car. Can someone please advise me what type and quantity of coolant shall I buy?
Genuine BMW coolant.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      11-13-2020, 01:49 PM   #4
Surly73
Drives: '11 535xi 8AT KWv3 MPE MHD xHP
This is strongly preferred. If you simply can't get it then G-48 is probably the closest.
      11-13-2020, 09:26 PM   #5
ngsir
Drives: BMW F10 520d
I check my coolant level once a week and fill to max mark. It really "drink" up a little for my 520d.
      11-13-2020, 09:56 PM   #6
Unspec
Unspec's Avatar
1300
Something's broken then. It's absolutely not normal and is quite worrying.
2015 BMW 535xi
      11-14-2020, 02:21 PM   #7
et7007
Drives: F10 F60 G01 E87
Get the EGR cooler checked. Its a common problem on N47 and N57 diesels.
Also you can check with dealer if yours is not under recall.
Staying with bmw
      11-17-2020, 06:35 AM   #8
t4ure4n
I am unable to find it our local BMW website. Do you know the part number for the coolant so that can look for it?
      11-17-2020, 10:27 AM   #9
Surly73
Based on https://www.ecstuning.com/b-genuine-...n/82141467704/
It seems like it would be 82-14-1-467-704
