01-17-2014, 12:08 AM | #1 |
Rep 540
wheels offset
I am planning to buy wheels but I don't know the right offset
what do you guys think about these offset? http://www.ebay.com/itm/20-Rims-Fit-...21256254046%26 |
01-17-2014, 02:50 AM | #3 |
Rep 540
01-17-2014, 08:24 AM | #4 |
Rep 147
Should be fine - Im running 9.5 F and 10.5 R
Black Sapphire 550i | HRE P40SC | H&R Springs | Active Autowerke's Exhaust & Downpipes | BMS Stage 1 | M5 Sway bar | V1
01-17-2014, 08:48 AM | #5 |
Rep 213
put your wheel specs on willtheyfit.com, as suggested by another forum member,
most you can go is 20 front , 25 rear (ideal is 25 F, 30 rear), so should be ok, but would go with better tires, like conti dws. |
01-17-2014, 11:55 AM | #6 |
Rep 29,202
The wheels will stick out a few mm if the car isn't lowered.
Take a look at this, it has OEM 20" wheels with 10mm spacers front and 20mm rear, but it's dropped on springs. http://f10.5post.com/forums/showthread.php?t=909064
01-17-2014, 12:48 PM | #7 | ||
Rep 540
How about the offset?
01-17-2014, 01:24 PM | #8 |
Rep 29,202
I didn't mean you needed spacers, but the OEM wheels with those spacers makes the offset ET23 front and ET24 rear, so not far from the wheels you want to buy.
