2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum BMW F10 A/C issue - professional help needed!
      08-02-2018, 03:06 AM   #1
Bayerman
Drives: BMW F10 525DA -10
I have F10 525DA with 3.0 N57, produced in 6/2010.
After I bought the car I found out that compressor clutch was gone, I mean literally come off and disappeared.
Well I bought an used compressor with low mileage from Ebay, and AC worked perfectly for a month after we replaced it.
Then AC suddenly stopped working, started slowly to blow hot air only. After few days AC was working again, drove about 70km and again it was gone!
When I push AC button on, compressor clutch engages. You can hear it engage and also see the clutch spinning - so I assume compressor works like it should? Also checked refigerant and there was 750g on the system. We did fill it up to 850g and still nothing.
With Autocom tester there was a note that compressor had "break-in" mode, which we did shutdown and surprise - AC was working again but only for few kilometers
So at the moment I am totally clueless what I should do next any good ideas?
I think there might be a minor leak in the system (probably condenser), as after a month there was 750g of refigerant. But I think AC should still work, even if there was a small leak?
I did install Ista+ and was able to read fault codes:
http://i68.tinypic.com/500j7n.jpg
Also did run compressor break-in mode but didnt help this time
What should I try next? Is it possible that pressure sensor is faulty? I think compressor clutch should not engage if the pressure is too high or low or there is not enough refigerant?
      08-02-2018, 03:07 AM   #2
Bayerman
And one thing I want to add, when I switch AC on it will start to blow hot air - hotter than outside I think. Could water valve be faulty or the flaps?
I just found out that drier wasnt replaced when new compressor was installed. Is it possible that drier is now clogged and causing these issues?
      01-30-2024, 08:34 PM   #3
Trickd122
Drives: F10 528 E39 ///M5
He'll, did you ever solve this?
