01-20-2024, 08:15 AM | #1 |
Rep 251
Ground straps
Have anybody ever had to do this on any BIMMER? $25 I might get one just cause.
01-20-2024, 08:30 AM | #2 |
Rep 1,873
Which one is that? I was doing some other work with all the bottom covers off of mine and there's some blue-ish corrosion in my transmission ground strap so I'm thinking of putting that on my list. Early on in the investigation phase though.
01-20-2024, 09:38 AM | #3 |
Rep 251
Idk, but just looking at description it says tranny or engine
01-20-2024, 02:02 PM | #4 |
Rep 3,003
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
That looks like the interference strap grounding the valve cover/coils.
01-20-2024, 03:30 PM | #5 |
Rep 831
The original BMW part as shown on the left side of the OP's illustration, is part number 12427581396, and has been superseded by 12428643430 on the following vehicles:
....if you are going to replace with OE, buy the latest version. |
01-20-2024, 04:04 PM | #6 | |
Rep 251
01-21-2024, 12:26 PM | #7 | |
Rep 831
I don't know how "flexible" the aftermarket ground strap shown in your original figure, but I would NOT recommend using that between something that vibrates (engine or transmission) and one that does not (chassis). There is the potential of transmitting more than just electrons (or holes) through the "stiff" wire. I'd trust that BMW uses a very flexible ground strap for a reason on their vehicles at certain locations. And when signs of corrosion or "wear", replace with OE ($40). IMHO. |
Double Nickel165.00 |
01-21-2024, 01:19 PM | #8 |
Rep 146
Drives: 2014 BMW 528i
I have it on my car and briefly helped them test it on my car. Its a thick gauge wire but its still flexible enough below the car. I recommend it if you want a piece of mind on something thats always exposed to the elements.
Tri Nguyen
01-21-2024, 01:22 PM | #9 |
Rep 146
Its exactly for this ground strap. goes from the chassis to the bottom of the transmission
Tri Nguyen
