2010 2011 BMW 5 Series Forum F10 Stripped Cylinder head changing Spark plug help |
07-10-2019, 02:04 PM | #1 |
Rep 590
I stripped cylinder head 5 changing my spark plugs.. I know I'm an idiot for it does anyone know what I should do to fix ? I bought a HeliCoil repair kit but I have no experience on how to do it myself..
If I take it to a Indy shop they will try to get as much money out of me in which I can't afford.. |
07-10-2019, 03:48 PM | #2 |
Rep 470
Pretty sure you need to remove the head to do any work, a helicoil will create tons of metal flakes that you don't want getting into the combustion chamber. How did you strip it exactly? Crossthreaded?
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280' |
07-10-2019, 05:19 PM | #3 |
Rep 151
Bluntly, sounds like you are in over your head.
An independent shop may be the best course of action with experience in correcting a delicate situation. |
07-10-2019, 07:10 PM | #5 |
Rep 659
To do a helicoil you drill out the threads, retap, insert coil, break off end.
All sizes and threads in compliance with coil chart. That being said, I agree with the above, pay the money. |
07-10-2019, 09:02 PM | #6 |
Rep 5,379
07-10-2019, 11:04 PM | #8 |
Rep 1,299
Maybe this might help you if you want to take the head off your self:
https://www.e90post.com/forums/showthread.php?t=1348442 |
07-11-2019, 02:45 PM | #9 |
Rep 659
Head doesnt have to be removed, been there done that with a 4V 4.6 DOHC engine. Stripped the spark thread doing a spark plug change, had it towed to a shop, took them 2-3 hours to heli coil it and never had any issues. Definitely take it to a professional shop to avoid any additional damage. I rememeber they said they put red lock tight on the outter side of the helicoil before threading it in too.
07-14-2019, 09:30 AM | #11 |
Rep 1,214
Repairing threads on a cylinder head while installed on the engine is very very very difficult to do on a modern BMW direct injection head as the spark plug bore is very narrow AND not straight in. Any cutting and installing tools are not going to be able to tackle the repair from the installation side. It must come in from the chamber.
The only way a reliable repair is going to occur is with the cylinder head off of the engine. You are going to have a professional correct it, and it is going to be a lot more than what it would have been to let them carry out the spark plug service correctly to begin with. |
07-14-2019, 01:18 PM | #12 | |
Rep 590
07-14-2019, 03:21 PM | #13 | |
Rep 5,379
So that demands the question... What's less expensive, a new empty/used head or fixing the current head? |
07-18-2019, 04:47 PM | #14 |
Rep 659
put clothes line coated in grease down the spark plug hole slowly making a coil on top of the piston. Greased up the drill bit and tap and then remove it
https://www.ecstuning.com/b-lisle-pa.../lis65200~lis/ Just call a few shops and get a quote |
