2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications F10 N55 ER Down Pipe Install DIY
      08-20-2016, 06:15 PM   #1
Infamouscrew02
Infamouscrew02's Avatar
75
Drives: 13 535 M-Sport
Cool
Briefly looked around for a DIY to install a Down Pipe on my f10 n55 and didn't come up with much. Saw a bunch for the f30 but not the f10. So I figured I'd make one. Obviously this would be easier with a lift, but I managed just fine doing it on my garage floor with the front end jacked up.
REMOVING THE DOWN PIPE:
Step 1: Pop hood and remove the engine cover.
[img]https://c2.staticflickr.com/9/8350/2...4363a668_c.jpg[/img]
Step 2: Remove sensor on the intake tube.
[img]https://c4.staticflickr.com/9/8624/2...bae723d1_c.jpg[/img]
Step 3: Remove intake.
[img]https://c5.staticflickr.com/9/8260/2...1da3f788_c.jpg[/img]
Step 4: Gain access to the o2 sensor connectors and disconnect.
[img]https://c2.staticflickr.com/9/8284/2...48348b81_c.jpg[/img]
[img]https://c2.staticflickr.com/9/8667/2...75a1219b_c.jpg[/img]
Step 5: Remove body shield to gain access to the down pipe. (A electric impact drill makes this a step go by a lot faster, there are a lot of screws.) Size 8mm
[img]https://c2.staticflickr.com/9/8160/2...06622d46_c.jpg[/img]
Step 6: Loosen up the down pipe and mid pipe band clamp. Size 15mm
[img]https://c7.staticflickr.com/9/8517/2...e23505c6_c.jpg[/img]
Step 7: Remove the two nuts that hold the down pipe brackets in place. Size 13mm
[img]https://c1.staticflickr.com/9/8081/2...f36b951a_c.jpg[/img]
Step 8: Loosen and remove the V-band clamp that connects the down pipe to the turbo. 13mm
[img]https://c2.staticflickr.com/9/8025/2...aa2e597f_c.jpg[/img]
Step 9: At this point you can apply pressure and the down pipe will separate from the turbo housing. You will also need to apply pressure to the mid pipe while wiggling the down pipe to separate the two. (Took some convincing to get them to come apart.) Once they are apart the down pipe will be free and you can slide it out from under the car.
Step 10: Remove the o2 sensors from the stock pipe and install into the new down pipe.
[img]https://c7.staticflickr.com/9/8791/2...dd2c8000_c.jpg[/img]
Here's the difference between the two:
Catted:
[img]https://c7.staticflickr.com/9/8098/2...679f12b2_c.jpg[/img]
Catless:
[img]https://c6.staticflickr.com/9/8196/2...bcc80b0f_c.jpg[/img]
INSTALLING THE ER DOWN PIPE
Step 1: Slide the down pipe and the mid pipe together.
Step 2: Slide the down pipe brackets onto the mounting bolts.
Step 3: Alight and slide the down pipe into the turbo housing.
Step 4: Install and tighten the V-Band clamp onto the down pipe and turbo. This step is important to make sure you get a good seal.
Step 5: Tighten the nuts onto the bolts that hold the down pipe brackets in place.
Step 6: Tighten the mid pipe band clamp.
Step 7: Fish the o2 sensor connectors up into the engine bay and reconnect them.
Step 8: Install the intake and engine cover
Step 9: Start the car and be amazed by the glorious sound.
Tips and trouble that I ran into:
I had a hell of a time getting the ER down pipe into the mid pipe, I had to expand the mid pipe inlet out some so that it would slide in.
When trying to get the down pipe to seat in the turbo, I wanted to blow the damn car up and burn my house down. It was very frustrating. Finally after many tries I pulled the pipe out and compared it to the stock down pipe. Only difference I saw was that on the ER pipe, the holes for the brackets were just barely big enough to go on to the bolts. The holes were much smaller compared to the stock DP. I got the drill out and made the holes bigger and the down pipe slid right onto the turbo.
Also, wear gloves when working on this project. My fingers got all sorts of cut up while working on this.
      08-21-2016, 12:59 AM   #2
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
Nice write up man!
IG: @bmwdoubles
      08-22-2016, 06:59 PM   #3
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
Very helpful, thank you!!
https://x-ph.com/sale/
Phone number 702-494-9435
      08-24-2016, 11:47 AM   #4
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Thanks! Will save this for future references. BTW any gas smells? How does it perform?
      08-24-2016, 11:56 AM   #5
Infamouscrew02
75
I haven't noticed gas smells. I do notice the exhaust fumes are a little more pronounced if you idle for a long time. Nothing smells within the cabin.
Definitely can hear the turbo spool much more pronounced. The boost hits sooner in the RPM range and I can see the values in my p3cars vent gauge climbing quicker.
Love the exhaust note. Seems like some of the drone has been taken from the in cabin as well.
      08-24-2016, 12:07 PM   #6
mike@x-ph.com
As with any catless, if you keep the car on idle for a while you will notice gas smell (on the outside of the car only, no smell inside)
99% of the people are fine with it since you rarely have the car on idle for a long time but if you are very sensitive to the smell get the catted option
      08-24-2016, 02:34 PM   #7
lsturbointeg
Can you describe the tone of your exhaust...did the tone get higher in pitch/tone or just louder if you know what I mean? Or is it more raspy? I know the Meisterschafts I got will be pretty loud especially when they are open but with DP's I was a little bit concerned if it was going to be obnoxious loud
What other performance mods have you done Silver? As soon as I'm done with the exterior mods I'll be working on performance next. The only thing I have but it's sitting in storage is my Meister's but I've been doing enough research that a tune, DP, CP is on my list
      08-25-2016, 05:07 PM   #8
mike@x-ph.com
Instead of describing, post a video
My advice to you is to do the exhaust first and if you still want more sound get the downpipes.
      08-25-2016, 06:03 PM   #9
izaazk
Drives: 2013 335i
Also interested in how it sounds! I have a f10 535i and debating between catless dp or catback
      08-26-2016, 02:24 PM   #10
Infamouscrew02
75
I'll work on a video soon.
      08-29-2016, 05:26 PM   #11
Secret_Asian
Drives: f10 lci luxury line
n55 catless sounds decent, not too loud no drone but on cold start its noisey
      08-29-2016, 11:19 PM   #12
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Ya need cold start delete
IG: @bmwdoubles
      08-30-2016, 07:39 AM   #13
FSociety
IG @bmwF9xG80
FSociety's Avatar
3810
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
Then get a N20 hahaha jk
Let it be, catless is not that loud after a few seconds just the initial start.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      08-30-2016, 02:29 PM   #14
Secret_Asian
already have it I figured I'd say that because most people probably dont, much better with cold start delete
      11-15-2017, 11:40 PM   #15
Shnitzer
Shnitzer's Avatar
Drives: 2011 bmw 535i
Thumbs up f10 turbo downpipe install
Thanks a lot for the detailed instructions on downpipe install , Mustered up the courage to do it in my garage worked out well about 2-3 hrs . I probably would not have done it without a lift if I had not seen your write up thanks again!
this makes a big improvement everything feels better , I still retained factory mufflers car is quiet with a little burble at idle ( Very little) I like it !
Last edited by Shnitzer; 11-15-2017 at 11:54 PM.. Reason: fogot to mention the sound of exhaust
      11-16-2017, 03:26 PM   #16
Proimport
Drives: 2014 BMW 535i
Cel?
Any check engine light?
      07-15-2018, 09:35 PM   #17
jderek22
jderek22's Avatar
Drives: 2011 BMW 535i
Hello,
I am currently trying to replace my downpipe. I have a question about your install. How were you able to access the nut on the top bracket of the original downpipe?
Thanks,
Jon
      07-16-2018, 06:51 AM   #18
sweettalker
Drives: Vrooom
Anyone in socal area have downpipes? I feel mine is getting too much rasp by the dp area almost like an exhaust leak sound when giving it throttle. My installer says it is on proper,but im not sure. It sounds like when the mating part is not fully tightened on the exhaust piping.
Can anyone in socal help me out and let me hear ur car? Im in la area koreatown midwilshire
      07-16-2018, 11:55 PM   #19
chris_mauck
Drives: 2016 M5 | BM3 | GTC Cat-Back
Nice work. Just did mine today, took longer than expected. Sounds great other than a small exhaust leak I can't get to seal up.
      07-18-2018, 06:58 PM   #20
ssgm1x
ssgm1x's Avatar
Drives: 2020 M340i & 2018 M3
F10 N55 currently running High Flow Catted DP but that will change tomorrow. Going to gut out the $900 High Flow AR Design Cat so when i take car to BMW at least it looks like i have a Catalytic converter....Lol.
Im just tired of the stock sound and also want some burbles. Also got a "catalytic efficiency below threshold" code after 3 months with my high flow cat so why not gut it now.....nothing to lose at this point.
2020 BMW M340ix Dravit Grey
2018 BMW M3 Alpine White
      07-21-2018, 11:42 PM   #21
John H.
John H.'s Avatar
Drives: 2014 535i XDrive
In the very near future, I will be installing a catless DP. I work in 90210, and can stop in K-Town. I'll keep you posted.
      07-22-2018, 11:20 PM   #22
_BSMM5
_BSMM5's Avatar
Drives: 2015 M3
2007 BMW 335i  [0.00]
How much do you think a garage would charge to install this?
