2010 2011 BMW 5 Series Forum F10 Bavsound Revenant Pro Amplifier Install |
06-27-2021, 01:44 AM | #1 |
Rep 96
I finally got my Bavsound Revenant Pro Amplifier after all the delays. Installed it today. Everything went well, but when installing the amp cover and panels back there isn't enough room. The amp being upright makes the wires stick out too high, and there is no room to flip it. I tried to install the panel without the cover, and it still doesn't fit. There is a bulge in the side pocket and it bends the optical cable and power/ground. I have emailed bav sound to see what they suggest. In the meantime, I have ordered some 90 degree optical cables and will work to do the same on the spade connectors for the power and ground. This might give me enough room, but I think I am pretty sure it still wont fit.
I did a basic test of the amp, and the audio actually does sound quite a bit better. I have the bavsound speakers all around and the 8ohm ghost subs. I will get if a better test tomorrow when I can get out and do some driving. Anyone have any thoughts or feedback if the 2ohm subs would make any difference for this setup vs the 8ohm? There is extra wiring in the pic. I have the musicar level 3 add a sub kit. JL Audio 10" W6 Sub-woofer paired up too a JL Audio XD600/1v2 amp. |
06-27-2021, 10:49 PM | #3 |
Rep 14,521
my Matchup7BMW fit perfect. i'm surprised Bav allowed this setup cause usually they keep thing neat and clean.
John H.230.00 |
06-28-2021, 11:07 PM | #4 | |
Customize Everything!
44
Rep 279
Question....do you have the Harmon Kardon Logic 7 amp previously? i noticed you used the added fiber optic cable adapter and I'm curious as to why? |
06-30-2021, 03:52 PM | #5 |
Rep 1,156
apparently they are supposed to be shipping a replacement amp for the HK system....not sure if you've seen that on their site yet..
06-30-2021, 05:29 PM | #6 | |
44
Rep 279
07-01-2021, 11:58 AM | #7 | |
Rep 1,156
How's the sound compared to stock? is it worth the 1500 or so? i have all the bav sound speakers already installed.. Good luck with the wiring, Bav Sound customer services is good...i'm sure they'll have a solution or work around... Last edited by xxpanipuri; 07-01-2021 at 01:56 PM.. |
07-02-2021, 09:52 AM | #8 | ||
44
Rep 279
Is it worth $1500? There are cheaper amps out there that you will have to do the tuning yourself. The price tag for the Revanant Pro is considering the added MOST adapter and the plug and play nature of the Amp. Set it and forget it. Your mostly paying for the "ease" of seappability from factory to Revanant Pro Amp. To me it makes it worth the price tag. Should be about $500 less lol |
07-02-2021, 09:54 AM | #9 |
44
Rep 279
My right angle rca adapter and optical cable came in yesterday. Going to swap out those wires and sound proof the right side of the trunk this weekend. Hopefully I can get some better pictures to share also.
07-03-2021, 03:26 AM | #10 | ||
Rep 96
"Thanks for your patience and the picture. The power cables can, gently, be bent to allow clearance, and there should be enough room on the fiber optic as well. If you want to buy a 90 degree angle plug fiber optic cable we can reimburse you for that via refund if you'd like. Keep us posted. As for the woofers, the sub channel is programmed for the 8 Ohm woofers. The 2 Ohm will draw too much power and sound bad until they eventually blow. Thank you so much for choosing Bavsound for your audio needs. We truly appreciate it, and we're committed to making sure you get great sound in your vehicle. Please let me know if you have ANY further questions or I can help with anything else." I tried what they referenced, but there isn't enough room. There is a plastic panel that goes over the amp. (in pic). I tried to bend the power / ground and used a 90 degree optical cable. There is still nowhere close to enough room. Even with the power and ground removed, the plate doesn't fit. This plate is what supports the side pocket in the trunk. Without it there is no structure to the pocket. I think they are going to need a different mounting solution for the F10. I emailed them back and will see what solution they return with. So far they have been very responsive. |
07-03-2021, 08:08 AM | #11 |
44
Rep 279
They recommended it being OK to remove the plastic cover and leave it off. But your right where there is no support without it.... Because the mounting is too high and you can see it starting to bulge because of the wires. I installed the right angle adapters for the optical and rca jack. It helped with clearance and the bulge is not so noticible. It helped with realigning the carpeting properly. For me, I can live with it for now.
I was more focused on sound proofing the trunk. I put some more deadener on the floor of the trunk in front of where the main wire harness from the battery drops into the frame of the car. Also around the 1/4 panels and some behind the gas cap door. I don't get the rattling anymore, so I am happy with the setup. |
07-04-2021, 09:14 PM | #12 |
Rep 96
I decided to just resolve this on my own. I removed the mounts, and trimmed them so that they fit back in sideways. This allowed the amp to lay flat. I think used the strong velcro to attach the stock module and the MOST box to the amp. I used the factory holes to mount the modified bracket. I was able to use one existing hole on the bracket itself and only had to add one. Just used a couple of bolts to attach it. Everything fits perfect and allows the factory plastic support to be added back in. Everything fits perfect now. Glad to have this resolved.
07-05-2021, 08:58 AM | #13 |
Rep 57
Looks good Donkeee. Perhaps bavsound will come up with an f10 bracket in the future to address this issue.
Edit: I noticed you cut off the part of the bracket that holds the cooling fan. Did you remove the fan, and if so, are you concerned about heat buildup? Last edited by DL7; 07-05-2021 at 09:11 AM.. |
07-05-2021, 11:31 AM | #14 |
Rep 96
It wasn't mounted at the time i took the picture. Fan is still there. I zip tied it in a good place to keep airflow.
07-07-2021, 12:34 AM | #15 |
Rep 96
Lastest response from BavSound. I am again very disappointed with this response. Glad I resolved this myself, but I want to make sure F10 owners know what they are getting into. I dont think they understand the F10 setup, and are punting the issue with a "compromising" fix. Their setup is not plug and play as they mention. They should make people aware of this issue prior to dropping $1600. If I had to do it all over again, I would probably go with a Helix of Germany MATCH UP7DSP Premium 7-CH Amplifier and just use the Helix most adapter. Would have probably been easier.
Just wanted to chime in here, that the support bracket needs to be removed to install the Revenant Pro, same as shown in the F80 M3 in our install video. This of course does reduce the effective weight capacity of the left hand side trunk carpeted pocket, but as long as you are keeping lighter items in there it's totally fine, and a compromise to have the more powerful amplifier. Getting Justin trained on all this, so sorry he didn't make that more clear earlier. Please let me know if you have any further questions, or if I can help in any other way. Jeremy |
DL711.50 |
07-07-2021, 11:15 PM | #16 |
Rep 57
A bit disappointed to see their response to you, especially given the premium price they are charging for a supposedly plug and play solution. Having to buy different wires and/or not having a factory support panel fit back properly is not plug and play to me. Glad you figured out a solution, but not everyone will be comfortable cutting metal (or have the proper tools already).
I had been thinking about pre-ordering the amp but then the initial shipping delays occurred and gave me pause. The amp is sold out now, so I guess it is a moot point, but this doesn’t exactly make me want to rush to order. I may end up following your work around or look into other alternatives. |
07-12-2021, 02:24 PM | #17 |
Rep 1
Plastic plate can fit with modification
I just finished installing the Revenant Pro amp in my 2015 550i with Standard HIFI. My system doesn’t require the MOST adapter or any fiber optic audio cables. However, as stated above, even the power cable portion of the amp sits too high for the plastic support plate to be installed.
I trimmed away some of the honeycomb plastic on the bottom of the plate, right where the power cables protrude. I also bent the power cables down 90 degrees. With this combination, the plastic plate can be reinstalled. The two outer “feet” facing the interior of the trunk don’t rest all the way down, but the carpeted liner can be reinstalled and it seems fine. I’ve attached a pic of the honeycomb shaved away (I used pliers to initially cut and peel away, and then a Dremel with a circular wire brush to clean it up). |
09-16-2021, 05:48 PM | #18 |
Rep 38
Apologies we aren't as active on the forums these days! I did just want to confirm we are now supplying updated 90 degree TOSLINK cables with these kits (back in stock late next week), so this will not be an issue moving forward.
We did reimburse anyone who ended up having to purchase a cable, and if you did and have not been reimbursed we would be happy to take care of you if you email support@bavsound.com |
