2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum is light steering normal for highway speed?
      09-15-2015, 10:50 PM   #1
Tk718
Drives: 2021 m550i
New '15 f10 535 xdrive, noticed inaccurate and wandering steering at speeds above 60mph. I constantly have to make small adjustments to keep the car straight. if I hit a bump at this speed the steering wheel almost wants to turn on its own, so unlike previous f30s I have to hold the steering very tight. It doesn't matter if I'm in sport or normal mode.
Am I expecting too much from this car or this is normal ? Please share how you f10 steering feels.
      09-16-2015, 01:39 AM   #2
The Beast
The Beast's Avatar
Drives: VW Transporter Sportline
Although the steering is lighter than on previous BMW's that I've owned mine is fine in terms of tracking straight at speed. have you checked if your tyre pressures are ok and not over inflated? You could always try running them at a slightly lower pressure...
      09-16-2015, 10:17 AM   #3
NvrNuff_ForMe
NvrNuff_ForMe's Avatar
Drives: 535i
For mine, at highway speeds steering feels heavier...which I really like. On surface streets the steering becomes lighter.
      09-17-2015, 12:10 PM   #4
Keyser Soze
Keyser Soze's Avatar
Drives: 2023 X5
I've had this issue since new. It wanders all over the place, especially in comfort mode and you have to make an annoying amount of tiny corrections all the time.
F10's steering, even in the supposedly better LCI 2014+ versions, is still very soft and light. If you are coming from even an F30, it's going to be noticeable. If you are coming from an E90/E46 it's going to be horrifying at first to get used to. If you are coming from an MBZ or Lexus - HEY IT'S PERFECT!
Different tires help a little bit but not much.
2023 G05 X5 x40i Phytonic Blue
....many prior BMW's back to a 1966 1600
      09-17-2015, 12:19 PM   #5
The X Men
Drives: 2013 X3 35i
The F10's steering is light compare to the older BMW or its's smaller counterparts, but in no way is it inaccurate. I cannot drive with one hand doing 100 MPH like I can with my old E90, but at the same time, I do work up a sweat trying to park my F10.
      09-17-2015, 01:25 PM   #6
Bbb34
Drives: '11 535i 6sp. DHP/RWD
Originally Posted by The X Men View Post
The F10's steering is light compare to the older BMW or its's smaller counterparts, but in no way is it inaccurate...
+1 although I personally like the heavier steering of the older models.
As for F10 being inaccurate or wandering, that shouldn't be the case.
Assuming no issues with tire pressure and alignment, and road being perfectly flat, it should track straight, I know mine does.
They do however tend to be sensitive to even minimal slope on the road (which isn't always obvious to the driver). They will gently want to follow the slope, and I was told - no first hand experience, this is more obvious wider the tires are (X5 was used as an example).
      09-17-2015, 04:00 PM   #7
IanS100
IanS100's Avatar
England
136
Drives: 520d F10 LCI M Sport
Like Keyser Soze, I find my f10 needs far more small corrections than I would expect. On roads with lots of bends / curves the steering is fine, the car goes exactly where it is pointed and handles remarkably well for such a big car, although I find the steering far too light even in sport mode. Put the car on a motorway however & drive dead straight (or straightish), that is when the small corrections have to be made, it feels a little like your driving on a windy day!
      09-17-2015, 05:33 PM   #8
Keyser Soze
Drives: 2023 X5
Yeah and note I had my old E46 and E90 alongside the F10 - so I was driving them different days of the week and the steering input was completely noticeable in the F10.
It's not a lot or like a 1968 Impala - but it is about 2 cm's of constant correction where with the other two they would steer themselves. Ditching the runflats to Michelin PSS's didn't help either.
Other than that I think it handles great as well for such a big girl.
      09-23-2015, 10:11 AM   #9
Dave4501
Drives: F10, E70, E64, and E60
My 2012 535i steering improved significantly on the highway when I changed to newer tires. The original tires were wearing on the edges and I think the wear affected it tracking right on the road.
I bought the car at 20k miles and had the alignment done plus added newer tires. That helped my steering quite a bit and may help yours.
'12 535i,
'12 X5,
'15 Boxster
RETIRED: '08 650i, '07 530i, '06 330i, '00 323ciC
      09-29-2015, 05:02 AM   #10
CLKFAN
Drives: F10 528
There is a program called the "program for steer ahead"
See this post with a scanned work order from BMW of Monrovia. It may help.
http://f10.5post.com/forums/showpost...7&postcount=20
