2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Marketplace Owner's Marketplace - F10/F11 Classifieds FS: ESS E-Tronics Tuner for 550i
      08-04-2016, 08:27 PM   #1
2011BMW550i07
2011BMW550i07's Avatar
Drives: 2011 BMW 550i
USD 600.00
✓ Will Ship
Sold
      08-06-2016, 08:21 AM   #2
dblock2151
Drives: '11 550i Msport DG
I'll take it for $500 shipped if you're interested
      08-06-2016, 05:32 PM   #3
2011BMW550i07
I will take that in a month if I get no other offers but I would like to hold off for right now. Thank you.
      08-07-2016, 04:20 PM   #4
dblock2151
Sounds good, thank you!
      08-17-2016, 03:38 PM   #5
2011BMW550i07
Bump
      08-18-2016, 06:59 AM   #6
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2019 M2 Competition  [0.00]
2002 330ci  [0.00]
How about actual photos of the ESS tuner?
      08-18-2016, 07:50 AM   #7
dblock2151
Also, what needs to be done as far as install? Do we have to send ESS any files, or is everything already loaded and good to go?
      08-21-2016, 10:46 PM   #8
2011BMW550i07
As far as I know on install this system is super easy to install it basically gets plugged into a few sensors. There is few setting into it like the max performance one is specifically tuned for mine with a 3" custom exhaust. So if you have exhaust should be the same. It just ups the performance and you will want to run 93 octane on the max setting. The others are just pre-configured but can be tuned how you want. They can tune a Eco mode and it's quick and easy to change between modes.
      08-27-2016, 12:31 PM   #9
Alohaaaaa
Alohaaaaa's Avatar
Drives: 2011 550xi
Still avaliable? And will you ship to Canada.
      08-30-2016, 12:15 PM   #10
2011BMW550i07
PMed you. Please contact me through there unless you can't. Please let me know
      09-07-2016, 02:16 PM   #11
2011BMW550i07
Were you interested I PM'd you and haven't heard anything back.
      09-07-2016, 02:18 PM   #12
2011BMW550i07
Bump everyone.
      09-10-2016, 07:41 PM   #13
2011BMW550i07
Bump
      09-22-2016, 08:02 AM   #14
2011BMW550i07
Bump
      09-27-2016, 02:29 AM   #15
2011BMW550i07
Bump
      10-21-2016, 01:50 AM   #16
2011BMW550i07
Bump
      11-23-2016, 04:29 AM   #17
2011BMW550i07
Bump
      11-23-2016, 08:30 PM   #18
The_M6
The_M6's Avatar
Drives: 2013 M6
I'm interested but curious how this differs from BMS.
Project Gamma Intakes / Project Gamma Catless Downpipes / Muffler Delete / DME Stage II Tune / H&R Springs
      11-24-2016, 03:39 PM   #19
2011BMW550i07
I couldn't say on the difference between the two. I think it all depends what you plan to do to your car. But you can get this one custom tuned how you want it. There is two custom tunes on the system currently and I think you can switch between 3 or 6 tunes total. And pretty easy to switch. You do obviously have to get to the unit in the engine bay.
      12-16-2016, 08:40 PM   #20
2011BMW550i07
Bump
      12-20-2016, 03:05 PM   #21
badblack550xi
badblack550xi's Avatar
i once held this unit in hand and build quality is top notch, many more connectors vs BMS.
2011 550i RWD 60-130 7.35
      01-11-2017, 02:00 AM   #22
2011BMW550i07
Both tunes push your car for stage 1 into the 460-470 range in the N63 motor. And same torque 520-530
Canbus gives you the BC control, then BCM module which I don't know if they provide anymore would be for stage 2 pushing 8+ in boost. So stage 2 with 93 octane and required would be pushing in the 490 to 500's with both systems. If you actually do your research on both you would see that.
Also you doing no splicing or mixing to wires. It's plug and play you unhook certain connectors with a male plug and plug the female side into the connector. You have full boost control thru the rpm range. Then can be unplugged quick when you bring it into bmw to keep your factory warranty. The JB4 will void your warranty so if anything goes wrong and they see wires being spliced or pushed into the connections and warranty was going to cover it you could probably say goodbye to that coverage. Just saying. If you guys really did your research you would understand. So if you don't want to void your warranty.
The control system gives you three main settings between
Program 1 - linear (low boost on launch)
Program 2 - Stage 2/torque (full power/boost) 93+ octane
Program 3 - Stage 1 91+ octane
You can reduce or max out each program so if program 2 for Stage 2 has too much power for daily use or whatever you can adjust the power curve down or just run it full.
JB4 doesn't give you that option, you have set maps to choose from and can't make any adjustments on the map.
You can also save settings to go back to. So if there is one you like the most it can be saved when you either deactivate or disconnect it.
