2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications N55 idle rpm.
      05-12-2019, 12:56 PM   #1
BurrNinja
Is this completely normal or would something be causing the idle to go up then back down? Only happens when cold after reaching a stop sign/light when I sit there. Doesnt happen when warm. Only thing I can think of is a method that the car uses to warm up quicker.
Instgram @burninja
      05-14-2019, 05:32 AM   #2
Surly73
Drives: '11 535xi 8AT KWv3 MPE MHD xHP
I've seen that for years on my 535xi. Usually it's accompanied with some torque converter grabs and releases too (leading to me wondering which is cause and which is effect).
Under extended warranty my dealer reportedly replaced all 6 injectors and plugs and it got a little better. The Internet seems to say that lots and lots of people have little oddities when the engine is cold. Then you read about the odd person where it was a Valvetronic actuator failure and $1k later "no problems".
It seems like you could throw tons of parts at it and still not fix it. Not sure if a "me too" is of any comfort. You could consider having the car scanned with ISTA to see if there's anything important logged.
BurrNinja430.50
      05-14-2019, 09:40 AM   #3
ziekxq
Drives: 2011 535i xDrive
I have this too and I already tried changing basic stuff. It doesnt do it as bad or as often as it did before. It usually very rarely happens with my car now.
I only changed coils and spark plugs. Also, check your air filter.
BurrNinja430.50
      05-16-2019, 09:16 AM   #4
BurrNinja
Buying a laptop soon to run ista, I have a bms intake its done it since I got it new. Ordering new plugs tonight.
Instgram @burninja
      05-16-2019, 10:08 PM   #5
NinetyEight740
NinetyEight740's Avatar
Drives: 2 - 2013 535i msport
2010 E91  [0.00]
Reprogram to latest software and see what it does
      05-17-2019, 10:48 AM   #6
BurrNinja
How would I go about doing this?
Instgram @burninja
      05-17-2019, 01:15 PM   #7
ziekxq
That might help. Come to think of it, I also updated my dme to latest version available. My mechanic did it for me.
      05-17-2019, 09:26 PM   #8
BurrNinja
How much did the software and dme updates run? I know I may need a transmission software update unless that comes in with the dme and software.
Instgram @burninja
      05-18-2019, 08:06 PM   #9
ziekxq
Everything gets updated along with dme such as tcu to seat module to anything you can think of. My mechanic charged me 50 bucks as a side job. But you probably looking at 200 to 300 bucks?
BurrNinja430.50
