2010 2011 BMW 5 Series Forum F10 M wheels on a 2016 535 xdrive |
03-23-2023, 03:39 PM | #1 |
Rep 28
Hi Guys
Will a set of 343 wheels of a 2013 M6 fit a 2016 535i xdrive without any issues ? I really like how they look Thanks
DBM
03-24-2023, 07:51 AM | #4 |
Rep 7,484
You can use the fronts on all 4 corners for a square set. Its' the rear wheels that have a lower wheel offset (if you go to one of the online part database sites (like www.realoem.com or www.bimmercat.com )...you can pull up the 343 wheel diagram to get the specs of the front & rear wheel. You can then compare them to the specs of the existing 20 inch wheels for the 535ix. I think most of the 20" wheels for the f10 have a 33mm front wheel offset and a 44mm rear wheel offset.
If you pull up the M6 wheel's specs...I think the rear wheel has a 19mm wheel offset. Again, the front wheel's offset is the same or close to the f10's wheel's offset specs. (I'm going off a foggy memory about some of the wheel offset specs...so verify in case I'm off a few millimeters)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
Dio7815.50 |
04-08-2023, 09:43 PM | #6 |
Rep 2,196
Agreed. I have been running my M5 wheels for 7 years now.
Bake
