2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum BMW N63 engine service action (Service Bulletin B001314)
      05-11-2015, 10:11 PM   #265
ForTehNguyen
Drives: IS
http://www.roadandtrack.com/car-cult...ns-bmw-n63-v8/
      05-12-2015, 08:22 AM   #266
RSBro
RSBro's Avatar
Drives: 2012 550i M-Sport
Originally Posted by ForTehNguyen View Post
Here's the Jalopnik article to go along with it too.
http://kinja.roadandtrack.com/why-bm...71504/+pgeorge
That read is crazy. It does not make me have good feels in my tummy about keeping this car...
2012 550i///M-Sport///Carbon Black Metallic///Oyster+Black Dakota///ZCV+ZLS+ZMP+ZPP+ZPS+ZSP+ZTP...M5 exhaust///iND Tricolor grilles///H&R Sport Springs///Turner Motorsport 12mm+15mm spacers
      05-12-2015, 01:15 PM   #267
4MULA_1
4MULA_1's Avatar
Drives: 550i
And this article from LeftLane: http://www.leftlanenews.com/bmws-twi...ies-88475.html
      05-13-2015, 12:17 PM   #268
pdrf10
A Man of Wisdumb...
pdrf10's Avatar
Drives: 2011 F10 550i M Sport
Very interesting articles - - thanks for the links.
However, I wonder how many of us with the N63 motor have had our batteries "chewed" through "every 10K miles", as mentioned in these articles? I had my original battery replaced at the 4 year / 36K mile mark, and truth be told, never had any issues. In fact, when I got my car back after the CCP, I remember reading the tech notes on my invoice which specifically mentioned my battery was operating within specs and was replaced per a technical service bulletin initiative.
Nonetheless, I'm glad that BMW is being proactive on this issue by replacing (and upgrading) batteries at their cost in most cases. I recently purchased a trickle charger and make it a habit to fully charge my battery about once a month in order to address some of the concerns mentioned in these articles, and hope the new battery will last 4+ years as well...
      05-22-2015, 12:36 PM   #269
RSBro
RSBro's Avatar
Just got my car back this morning... took it in Wed. Had a Drivetrain Malfunction error and ended up getting a VANOS solenoid replaced. Not sure if has to do with any of the 'recall' issues or parts, but just a heads up.
      05-24-2015, 01:21 PM   #270
Zer0Cool92
Drives: blue metallic
Are you under warranty?
      05-26-2015, 02:53 PM   #271
RSBro
RSBro's Avatar
yes, thankfully!
But only until Nov. 11 of this year... after that no way I'll be able to afford to keep this thing.
      05-26-2015, 03:05 PM   #272
493263
493263's Avatar
71
Drives: 2011 550i xDrive
I've had my N63 package done a few months ago. Since then I had to top off 3 quarts of oil in about 5000-6000 miles. Today, it threw drivetrain malfunction code on my screen when I was driving to work. My odometer is at 49,300 miles.
      05-26-2015, 05:16 PM   #273
Zer0Cool92
I had my CCP done about 2 months ago as well and was given a oil change. 3000 miles later I had to add some oil. These engines are known to go through oil quickly.
Are you under warranty? I wonder what the malfunction code could be from?
      05-27-2015, 09:15 AM   #274
493263
493263's Avatar
71
Yea I'm still under warranty until July. I also have the extended warranty.
      05-27-2015, 11:25 AM   #275
493263
493263's Avatar
71
My SA just called. The fuel pump malfunctioned. Let's hope there are no more problems from now on.
      05-27-2015, 12:28 PM   #276
CJPatel
Drives: SF90, Urus, V12Vantage, M8, M3
My car has been very unstable since the Recall, I get Drivetrain malfunction errors, and an Indy Shop said it was a misfire in cylinder 8, replaced coil and spark plugs. Now its a DSC and XDrive Malfunction upon start up. After I shut the car off once or twice it goes away. This is awfully embarrassing and stupid. Any help?
SF90, G63, V12 Vantage, E46 M3. DD: M4
Gone: AventadorS, Urus, 13' Ferrari 458, AM V12 Vantage 6spd, M8, F82 M4, 2013 LP550-2, F430 Spider, AM V8 Vantage 6psd, E92 335i 6spd, 2003.5 E46 M3 6spd, Audi A7, 2011 BMW 550i,
      05-27-2015, 01:38 PM   #277
493263
493263's Avatar
71
DSC and xDrive malfunction you're describing sounds more like an electrical problem. Next time it happens, don't reset the car. Just drive straight into a dealer and leave the car on. They can trace where the problem is. It could be something as simple as a loose battery cable.
      05-27-2015, 03:52 PM   #278
CJPatel
I'm. Hoping its that simple. I can't leavie it on though since it won't drive. It idles very rough then dies. It crazy struggles. I'm gonna take it into the Indy shop tomorrow and hopefully they can help.
      05-28-2015, 09:35 AM   #279
493263
493263's Avatar
71
I would take it in a legit shop(A BMW certified shop) and get it checked out. Seriously, if you keep driving a car with misfire, it will wreck your engine. You went cheap and took it to some indy shop that misdiagnosed the problem and it was a sunk cost fixing things that were not broken. Better to do it right the first time.
Just so you know. My car idled rough as hell and struggled to get past 2k rpm. It was a broken fuel pump and it is a recall fix.
      05-28-2015, 07:01 PM   #280
Zer0Cool92
Do you still have any issues with the rough idle after getting the pumps replaced?
      05-29-2015, 09:14 AM   #281
RSBro
RSBro's Avatar
My car's production date is post fuel-pump recall, so at least I dodged that one (for now)...
      05-29-2015, 09:54 AM   #282
493263
493263's Avatar
71
No, I have steady idle now.
      05-29-2015, 04:18 PM   #283
Zer0Cool92
What about any choking in the lower rpms (around 1500 rpm) when cruising ?
      05-30-2015, 11:22 AM   #284
eplace
eplace's Avatar
Drives: F10 550i
And to add to that question... also what about choking (shaking) when the car is stopped (at the light) with engine running? Just had my fuel pump replaced after the N63 care service. My injectors were replaced, so not sure why I'm experiencing this slight shake at idle...
      06-01-2015, 07:47 AM   #285
493263
493263's Avatar
71
Your car should not be choking at idle. Mine holds pretty steady and it doesn't seem like turning on all the accessories affect the idle since it's a different type of alternator. It could be anything fuel problems, fouled plugs, weak battery to Mass Air Sensor(or whatever it is called in the BMW). Sorry, this is the first car I don't service myself so I don't know much about it but should be similar to other cars.
      06-01-2015, 07:58 AM   #286
493263
493263's Avatar
71
Exactly what type of choking?
Does it stumble or is it just struggling because it's in the wrong gear? The normal mode or below is geared for gas mileage so sometimes it is in a gear higher than it should be. Sometimes it feels like the tranny doesn't want to kick down the gear while the engine is in limbo expecting the tranny to.
There's a high chance you might have bad gas. Go for several weeks at the same exact gas station and then switch to see if there's a difference. BMWs are very sensitive to octane level. US gas quality isn't that great compared to Europe. I see it happen all the time. In fact, my friend's M3 does it for years and he thought it was a transmission problem. Then it turned out to be bad gas.
