04-03-2012, 08:52 AM | #1 |
Rep 4,047
Wipers
Uh, how do I pull up the wipers in order to clean the windshield at the gas station? Tried it the other day and felt like a fool
04-03-2012, 09:22 AM | #2 |
Rep 2,612
Drives: F30 328i Luxury - Sport Auto
By exerting a force opposite and greater than the resistive force on the wiper.
Gone: 2006 BMW E60 520d SE 6MT Gone: 2009 BMW E90-LCI 330d SE 6MT Current: 2012 F30 328i Luxury 8AT On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!) |
04-03-2012, 10:04 AM | #4 |
Rep 2,612
Seriously, I just gave it a pull in the middle of the wiper (not over the hinge or close to the hinge) and up it comes (that is not what she said).
04-03-2012, 10:15 AM | #5 |
Rep 464
04-03-2012, 10:22 AM | #6 |
Rep 29,202
04-03-2012, 11:14 AM | #7 |
Rep 494
Drives: BMW 2011 M3
Oh yes very simple driver side
04-03-2012, 12:45 PM | #8 |
Rep 4,047
ok, will give it a go today. Thanks!
04-03-2012, 12:55 PM | #9 |
Rep 51
Drives: 535ix
Maybe this from page 64 in the manual ?!
Fold-out position of the wipers Required when changing the wiper blades or under frosty conditions, for example. 1. Switch off the ignition. 2. Under frosty conditions, ensure that the wiper blades are not frozen onto the windshield. 3. Press the wiper lever up beyond the point of resistance and hold it for approx. 3 seconds, until the wiper remains in a nearly vertical position. After the wipers are folded back down, the wiper system must be reactivated. Fold the wipers back down Before switching the ignition on, fold the wipers back down to the windshield; otherwise, the wipers may become damaged when they are switched on. 1. Switch on the ignition. 2. Press the wiper levers down. The wipers move to their resting position and are ready for operation.
2012 Mercedes-Benz C350 4MATIC Black/Sahara
2011 F10 535i xDrive MY 01/2011 Sophisto Grey / Black |
04-03-2012, 01:37 PM | #10 | |
Rep 4,047
04-04-2012, 08:31 AM | #11 |
Rep 4,047
That didn't work. Now what? Can someone try this and see if it works for them
but I did look like a fool at the gas station with my wipers running, while I tried to hold it repeatedly for "3 seconds" |
04-04-2012, 08:33 AM | #12 |
Rep 2,612
From what I understand, you want to lift the windscreen wipers up, so you can clean the section of the window underneath them, yes?
04-04-2012, 08:41 AM | #13 | |
Rep 51
Drives: 535ix
If you say the wipers were running when you pressed the lever beyond the point of resistance and hold it for approx. 3 seconds, it means the ignition was ON.
04-04-2012, 09:16 AM | #14 |
Rep 4,047
04-04-2012, 09:18 AM | #15 | |
Rep 4,047
I followed the manual that says "3. Press the wiper lever up beyond the point of resistance and hold it for approx. 3 seconds, until the wiper remains in a nearly vertical position." The above implies that the wipers will move until they come to a stop in a vertical position. Anyone try the way the manual is suggesting?? |
04-04-2012, 09:58 AM | #16 |
Rep 2,612
I'm so confused, this is absolutely stupid. BMW have complex, complicated designs but I'm sure they're not so stupid that you can't lift the windscreen wiper up to clean the freaking window!! I'm sorry but, "how hard can it be?!"
Lift, wipe windscreen clean, put down (if they haven't already jumped back down on the windscreen due to their weight to gravity and potential energy stored in the spring acting as resistance). I do apologise, but FFS, it can't be this hard, surely?! This is hilariously silly!
04-04-2012, 10:06 AM | #17 | |
Rep 28
Drives: F10 525d
04-04-2012, 10:20 AM | #18 | |
Rep 3,016
Another way to do it is with the ignition completely off (1st press to switch off engine, 2nd press to switch off ignition) the wiper arms can be manually moved to any position you want - just lift the blades slightly clear of the screen and apply gentle pressure to move the arms. It's even easier with a wet screen as you don't even have to lift the blades. |
04-04-2012, 10:26 AM | #19 | |
Rep 4,047
04-04-2012, 10:29 AM | #20 | |
Rep 3,016
On the F10 the rear edge of the bonnet precludes this action; the arms have first to be moved approximately 30⁰ from the horizontal, thereby allowing the arm hinge to be folded forwards. |
04-04-2012, 10:29 AM | #21 |
Rep 4,047
04-04-2012, 10:38 AM | #22 |
Rep 2,612
Well, I'm staggered, absolutely staggered.
Good luck with your wipers, OP, you'll need it! Brain surgery seems a simple task in comparison!!
