2010 2011 BMW 5 Series Forum F10 Help changing my 535 msport diffusor |
12-04-2015, 08:15 AM | #1 |
Rep 88
Got 2013 535 msport changing the diffusor to an m5 diffusor n its doesn't fix because of my dual tips. I looks like I need to move the tips over about an 1-1/2" is this possible to do? |
12-04-2015, 09:45 AM | #5 |
Road Killer
22
Rep 106
It can be moved
i had the same problem i got it moved. Depends what exhaust you have.
Haseeb
Current Daily Drivers: 2018 BMW M5 F90 Alpine White/ Aragon Brown Full Merino Leather, 20" M Double-Spoke Black, Formula1 15% Tints Retired: 2012 535Xi Carbon Black, Meisterschaft GTS Quad Exhaust And ETC |
12-04-2015, 11:28 AM | #6 |
Rep 14,522
You'll get better input if you post this in the general forum. You're in the ForSale forum. Your issue can be fixed. There's actually many threads covering this if you what exhaust do you have and can u post some pictures? The exhaust on the M5's sit more inward whereas the 5 series sits more outward.
12-04-2015, 12:57 PM | #7 |
Rep 2,188
Post some pics. You were running quad tips on an OEM 535 diffuser? Did you expand the exhaust cutouts on the OEM diffuser? You may need different tips. In order to run the M5 diffuser with stock mufflers (I'll assume this is what you have as you didn't specify something different), you will need tips with a "h" configuration (the top of the "h" being the muffler outlet, and the bottom "n" portion being the two outlets). The important thing to note is that one of the outlets is lined up with the muffler outlet, and the second one is offset towards the centerline of the car.
If you wanted to run a 550 diffuser, or a diffuser made for a 550, you would need tips with an upside-down "Y" configuration. Here the two outlets will be equally offset from the muffler outlet. The reason for the different configurations is the openings on an M5 diffuser are more inboard (towards the centerline of the car) when compared to a 550. It sounds like your setup could work on a diffuser made for a 550, but will need some work to fit properly with the M5 diffuser.
Bake
12-04-2015, 03:34 PM | #9 |
Rep 14,522
here's the tips mentioned. Same route I will have to do when I swap in my Mtech bumper and M5 DTM type diffuser.
Here my diffuser is for an M5 so I'll have to use those "h" tips posted above so I won't have to make any adjustments to the exhaust hangers.
12-07-2015, 09:02 AM | #14 | |
Rep 14,522
http://m.ebay.com/itm/2X-Staggered-B...7%2526algo%253 Reference this thread cause this is the problem you have and here's what you'll need to do. Also, he's got the link for the other tips I posted. http://f10.5post.com/forums/showthread.php?t=1097130
12-07-2015, 01:04 PM | #17 |
Rep 14,522
12-07-2015, 03:12 PM | #19 |
Rep 14,522
What piece is this. And BTW which diffuser did you get that won't work?
