2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Marketplace Owner's Marketplace - F10/F11 Classifieds FS: CKS Coilovers for F10
      06-09-2014, 07:33 PM   #1
IE92
Drives: 2015 F80 M3
None
For sale is a used set of CKS Coilovers for the F10. They are in very good condition.
CKS coilovers are built using only the highest grade materials. The upper mounts, lower mounts and spring perch are made out of 6061 T6 aluminum, and rely on SAE 9254 (500,000 times of compression test) springs and SCM440 hardened piston rods. Giving you a smooth and solid feeling ride, it doesn't matter if you're driving through city pot holes, or racing on a track at 100+ mph. The bottom line is that after all those years of development, CKS gives you a one of a kind coilover and a guaranteed peace of mind knowing you're driving with the most reliable, safe and highest performing coilover on the market.
-mono-tube shock design (inner polished seamless 55mm steel tube)
-44mm linear characteristic internal piston
-Italian IP F.A 5W shock oil: very high viscosity index guarantees efficient shock absorbing movement at any ambient temperature.
-hard anodized forged aluminum upper mounts spring perch and lower mount
-24 way dampening adjustability with a 12kg spring rate on the front and 10kg spring rate on the rear, making these CKS coilovers a true set of fully adjustable coil overs
Retail price is $1,850
Price - $875 + shipping
      06-11-2014, 12:26 PM   #2
LACSTER
Drives: Hybrid
for the coolest guy in the F10 game.
      06-18-2014, 11:22 AM   #3
IE92
Drives: 2015 F80 M3
Bump
      06-18-2014, 11:25 AM   #4
Mr.skytech
Drives: Point A to point B in style
Do these fit an F10 535 X-Drive?
      06-18-2014, 04:58 PM   #5
IE92
Drives: 2015 F80 M3
Unfortunately they do not. These will fit non-xdrive cars only.
      08-18-2014, 09:42 PM   #6
IE92
Drives: 2015 F80 M3
Price lowered to $875!
      08-18-2014, 10:41 PM   #7
ARKONE
Drives: '11 458; '16 Escalade; '12 Z4
Nice! What kind of drop does it give the car? 1.5"?
2018 Lamborghini Huracan Performante
2012 Ducati Panigale 1199 S
2019 Ducati Panigale V4R
      08-26-2014, 11:38 AM   #8
LiLS
Drives: ISF
what was the offsets on ur wheels and sizes?
      08-31-2014, 10:38 PM   #9
IE92
Drives: 2015 F80 M3
These are fully adjustable, so you can use them to lower the car as much or as little as you want to.
      09-04-2014, 11:36 PM   #10
LACSTER
Drives: Hybrid
