2010 2011 BMW 5 Series Forum F10 F10- Daytime Running Light Malfunction |
11-11-2015, 10:53 PM | #1 |
Rep 2
Hello,
New here i was hoping i could get some help on a issue i am having I went threw a car wash and got a message say daytime running lights malfunction. I noticed that there was moisture inside the driver headlight now my angel eyes on the driver side won't come on ant the self leveling thing is acting up, When i turn on the headlights i can hear like 3 clicks from something on the headlight kinda sounds like some ignitor not very sure. After the 3 clicks nothing happens, no angel eyes. Anyone have any idea what may be the problem? I don't know if the moisture blew out the bulb or worse burned out some module. Does anyone know how to remove the headlights, Does the front bumper have to come off? What module controls the angel eyes? Sorry for all the question, but my warranty just expired 2013 BMW 528I Base 2.0L |
07-07-2018, 08:28 PM | #2 | |
Rep 35
07-08-2018, 12:19 PM | #4 |
Rep 35
07-08-2018, 01:06 PM | #5 | |
Rep 767
First things first, maybe go to a shop and make sure this is what you need. Maybe just your DRL lightbulb went out and needs to be replaced. My symptoms for replacing the headlight module was I had all the error messages associated with the light. Daytime running light malfunction, adaptive light malfunction, turn signal malfunction, etc. I had water building up in the light for weeks until it finally went out on me. |
07-08-2018, 10:43 PM | #6 | ||
Rep 35
07-08-2018, 10:45 PM | #7 | |||
Rep 35
Also thanks I will have it checked out first , Do you recommend a European shop or Bmw dealership?since dealership booked till next week |
03-23-2019, 07:56 AM | #9 |
Rep 1
Hey can you help me out please I’m having a issue where my drl on My driver side one out after my wheel well cover fell off Resulting in zero functionality from the driver side head light but the drl went out before this so idk if it’s just a bulb and how can I find a new bulb online nothing comes up for bmw 535i xdrive 2011
03-23-2019, 12:57 PM | #10 | |
Rep 7,452
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
06-30-2020, 08:35 PM | #11 |
Rep 1
Hello guys did you get to fix this?
I have the same problem on my 2011 535i with adaptive xenon with water damage. I ordered the light control module 63117316217 on ebay and installed it but didn't fix it. I brought it to the indy and they reprogrammed the module and now my L turn signal works but I still have error messages on my dash for adaptive headlight malfunction, vertical aim control and my halo ring or angel ring for daytime running light is still not working. Has anyone experienced this where they bring it to the shop and daytime running light still not working and error messages still on dash?... Thanks |
07-22-2020, 07:48 PM | #12 |
Rep 7
Program control module?
I also have a 2011 535i with adaptive xenon with water damage. Replaced the control module. Any info on how to initialize or code it to the car? Brand new, so never coded before. Can it be done with Bimmercode or Bimmerlink?
Thanks, |
07-23-2020, 08:55 PM | #13 | ||
Rep 392
Its unlikely both modules went bad at same time. More likely your frm burned out. You can see my build thread about how to do it.
535D Xdrive DUDMD Stage 1
x5d e70 DUDMD stage 2 tune |
03-05-2021, 10:29 AM | #14 |
Rep 1
Hello,
I was hoping i could get some help on a issue i am having. After winter I got a message say daytime running lights malfunction, turning signal malfunction. I noticed that there was moisture inside the passenger headlight now my angel eyes and turn signal on the passenger side won't come on. I take headlight off. Clean i, dry it and put back. Everything works fine except angel eyes. No errors. When ignition is on angel eyes works fine, just start engine after 30 seconds angel eyes turn off. I change module from right side to left side no changes. Right side working no problem. When I see when I turning steering wheel or stop to traffic light passenger angel eyes turning on for 30 second and turning off. When my f10 on ignition all angel eyes working fine, just start engine after 30 seconds passengers turn off Does anyone know how to fix it? Here is no errors. |
