2010 2011 BMW 5 Series Forum F10 Suspension bentley torque specs... |
06-02-2014, 04:22 PM | #1 |
Rep 66
I just finished my H&R spring install and i'm wondering what are the torque specs for the F10? Cant find definite answers on the forums....
- Front Top Struts Bolts - Front Bottom Nut/bolt - Front Sway bar links nut - Rear Top Strut Nuts - Rear Bottom Strut Bolt Thanks, AJ
04-01-2016, 04:36 PM | #2 |
Rep 3,834
Did you ever gotten this info? I need the specs as well. For some odd reason, forum members won't share Bentley torque specs. This is what I gathered from random sources:
Control arm to steering knuckle M14 8.8 bolt (replace with new).....80Nm (59 ft-lb) M14 10.9 bolt (replace with new)....165Nm (122 ft-lb) Control arm to subframe M12 8.8 bolt (replace with new).....68Nm (50 ft-lb) + 90 degree M12 10.9 bolt (replace with new)....100Nm (74 ft-lb) + 90 degree Road wheel to hub........................120 Nm (102 ft-lb) - I just do mine at 95 ft-lb to be safe Tension strut to steering knuckle (replace wit new).....165 Nm (122 ft-lb) Tension strut to subframe M12 8.8 (replace with new).....................................68 Nm (50 ft-lb) + 90 degree Outer tie rod bolts ( 18mm nuts, and #5 allen ) : 65 Nm (48 ft-lb). Stabilizer bar bottom (16mm ) : 65 Nm (48 ft-lb) Struts .. TOP (3 nuts, 13mm) : 34 Nm (25 ft-lb) Struts.. BOTTOM (18 mm / 16mm ) : 81 Nm (59 ft-lb) E92 can't be too far off from our tq specs, as long as the bot size/dimension are similar. If anyone has this info the F10, that would be much appreciated. http://www.m3post.com/forums/showthread.php?t=183005
Daily: G12 750 MSPORT Weekend Car: E90 M3
John H.230.00 |
04-01-2016, 04:41 PM | #3 | |
Rep 14,522
04-01-2016, 04:54 PM | #4 | |
Rep 3,834
For lowering the car, none of those bolts should be impacted. Strut bolts are reusable. Oh, use BLUE Locktite for the thread. DIY thread below, but the OP wouldn't share the torque specs after many have asked: http://f10.5post.com/forums/showthread.php?t=628336
04-01-2016, 06:49 PM | #5 | |
Rep 14,522
04-01-2016, 08:36 PM | #6 | ||
Rep 3,834
04-01-2016, 09:48 PM | #7 |
Rep 14,522
04-01-2016, 10:03 PM | #8 |
Rep 3,834
Not the wheel lug bolts though, lol. Use anti-seize copper lubricants for that. TQ wheel lug bolts to 95 ft-lb (calls for 102, but 95 to be safe)
04-02-2016, 10:06 PM | #9 |
Dream crusher
984
Rep 2,421
Oh damn thanks
IG: @bmwdoubles |
