2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications F10 535 wont go into gear. Dsc/egs codes
      12-24-2023, 06:29 PM   #1
Bmweiner66
Drives: BMW e90 335xk & F10 535xi
Hi I’ve had my 535 for 6 years no problems. I left the car parked for the past 8 days, when I go turn on the car it won’t go into any gear,it also said the battery was very low & discharged, I did leave it low & forgot to leave it on a trickle charger despite me having my foot on the pedal , the car still says press brake pedal about every time I try to shift the gear. I’ve managed to reset the codes and let the car sit for 10-15 minutes, and the car will initially let me shift the gear until I put it back into Park , being locked again it doesn’t let me shift. Only once after I clear codes and let it sit. How can I fix this??? Can it be the DSC/ABS Pump??? I don’t want to buy/replace it knowing it not being the problem after but all my codes are mainly DSC,EGS related . Even though my AGM battery is only 2 years old I replaced/coded with a new AGM 95AH battery but nothing has changed. The last 4 pictures are the first codes when scanned after being very discharged, the rest are after resetting codes & turning car on. Anybody that helps me fix this issue I will happily send a 100 online for helping me!!!
