2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum 2014 BMW 535i M Sport - Retrofit Paddle Shifters
      09-12-2020, 09:46 PM   #1
Steve Miller
Drives: 2106 BMW 550i MSport
Im having a hard time finding the info (although Im sure its here somewhere)
I have a 2014 F10 535i XDrive w/ M Sport package. I don't currently have paddle shifters but am looking into the difficulties in retrofitting.
I know there is a couple of codes to change w/Bimmerlink but as far as the wheel goes, will my current M Sport wheel work, or will I need to find a different one?
Thanks!
Just to be clear, this is the wheel I have -
      09-12-2020, 10:45 PM   #2
rahdigga165
Drives: 2015 535i xdrive M-Sport
Thanks!
Just to be clear, this is the wheel I have - [IMG]https://ibb.co/T2zLkKh[/IMG]
If you want to use your steering wheel, You need to source the the paddle shifters and screws, the back steering wheel cover, if you have heated steering, you need new connections..then you have to code the car..replacing 205 with 2TB (do your research on this coding).
You going need to drill the paddles holes on the steering wheel to be able to mount them unless you want to spent hundreds $ on a steering wheel with the precut holes.
I can give you a head start on the parts you need
Back Steering wheel cover 32307848268
Paddle/ heated hardness 32307848332
Paddle shifter 61317848968
Paddle screws 32307848333
Its also good to change the gear selector to the one that comes with the paddle shifter package
Gear selector 61317950396
Good luck. Keep us inform on how you come along the mods.
      09-12-2020, 10:55 PM   #3
Steve Miller
Wow - Looks like you gave me all the info I needed - thanks!
2016 550i MSport
