2010 2011 BMW 5 Series Forum F10 What is everyone replacing there Run Flats with?? |
05-13-2017, 12:37 AM | #23 | |
Rep 5,375
05-13-2017, 12:45 AM | #24 |
Rep 697
Drives: 2013 535xi
Like when you get a blow-out at highway speed, and by the time you pull over, the tire is toast. Happened on my E39.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension 2000 528i, Cosmo Black, beige interior, Sport package (retired) |
05-13-2017, 01:24 AM | #25 | ||
Rep 1,684
Run flats can never be repaired. Non-RSC tires (traditional) can often be fixed and placed back into service with no degradation. Yes, if a traditional tire gets its sidewall damaged it must be discarded. But, by far, the most damage from nails, screws in the part of the legacy tire that can easily be repaired. |
05-13-2017, 07:23 AM | #26 | |
Rep 15,858
Not running at zero pressure is one area where we can influence the possibility for a repair. Top up the pressure, if we must run-on-flat. It is the internal inspection which is critical and typically determines whether it is possible to have a repair. Tire shops may have a different opinion, some won't repair even where the tire industry allows for a repair. |
05-13-2017, 05:36 PM | #27 |
Rep 397
Drives: Jet Black 2015 F10 535i
I switched my OEM 351 wheels with the M5 343 ones along some Michelin AS3 tires. Ride is more smoother compared with the run flats.
CQuartz UK 3 Ceramic Coating | GeoShield Pronano 50% Ceramic Window Film | M5 M Perf Steering Wheel | M6 Comp Pkg Mufflers | M Perf Floor Mats | CF Spoiler | RW CF Quad Setup Diffuser | RW CF Front Lip | CF Trim | BMW Interior Leds | M5 343 Wheels | Pure Stg 2 Turbo |
05-13-2017, 09:50 PM | #28 | ||
Rep 1,684
Even if you could perform a finite element analysis on all of the possible locations in a tire that can be repaired, once you take the size of the hole, the materials used to plug the hole and the various glues it's far to risky for any corporation leader to give its blessing because you now have three different states that the tire must perform: pressurized, partially pressurized, and flat. Too many variables. You show me one major tire company willing to repair runflats. There are none. You have no way to know how many times the tire went flat let alone the distance driven in its flat condition. This is why I say runflats are an unmitigated ecological nightmare. |
05-13-2017, 09:56 PM | #29 |
Rep 5,375
05-13-2017, 10:52 PM | #30 | |
Rep 1,684
Plus, you haven't shown me anything. Show me some legitimate corporate communique like an advertisement or other writings that clearly state they will repair RSC run flats. You think my wheel and tire insurance contracts would rather throw a way a perfectly good run flat rather than repair it if they could? Nope. Show me something more substantial than your word. |
05-13-2017, 11:20 PM | #31 |
Rep 5,375
Looks like Continental, Pirelli and Yokohama are the ones that recommend replacement.
https://www.tirerack.com/tires/tiret...jsp?techid=226 |
05-14-2017, 09:11 AM | #32 | |
Rep 1,684
You know, under any other circumstance I would pat you on the back and say you utterly won the argument. But, if you read the fine print on the document you provided, it completely contradicts the little chart that says "repair permitted." I think it's a bait and switch. Let me research this. |
05-14-2017, 01:58 PM | #33 | ||
Rep 15,858
Here's one of our most popular mobile tyre services understanding: http://www.etyres.co.uk/run-flat-tyr...un-flat-tyres/ Part quote: Quote:
05-14-2017, 03:43 PM | #34 | |||
Rep 1,684
Although, I still feel that it's a bait and switch in that there is wide latitude for the service center to refuse to repair. |
05-15-2017, 12:40 AM | #35 | |
Rep 5,375
Take care my friend! |
05-15-2017, 02:19 AM | #36 | ||
Rep 1,684
Plus, in response to your point, I did read that some customers have had trouble getting their runflats fixed (by companies allowing repair). This would suggest there is a seedy side to runflats as well. |
05-15-2017, 05:49 AM | #37 | |
Rep 15,858
One problem associated with liability, is the customer lying about the use when there is a puncture. The "only a couple of miles mate, since the warning popped up", type comment. I've spoken to a few guys in the business and they just won't take on the liability, or can't get insurance cover for that particular liability. Then the whole subject of the run-flat has often confused. We've had some tire shops getting users to sign disclaimers when changing from run-flats to conventional tires on BMW cars. Then there is the poor history/performance of the first generation run-flats. A current assumption all run-flats, even the latest generation are the same as those fitted back in say 2003. Changing from run-flats these days doesn't give the same changes as we experienced years back. Some of the latest generation run-flat tires are very close to the vertical stiffness of conventional high performance tires. I hated the run-flats on my 2006 3-series, changing to conventional tires, made a massive difference to the car. Happily run Continental Sport Contact 3 SSR on my F11, fitted the same again when the first set needed replacing. Yes, there is a small compromise in tire performance at the extremes. But after the hassle of a spare wheel, mobility kit, etc., in the 3-series, I didn't want the same with the F11 if tire performance had improved, which it has. |
05-15-2017, 07:23 AM | #38 |
Rep 233
Drives: my neighbors crazy!
OEMs have Michelins on them, my Niche's have V12s, which are being replaced with sumitomo tires today. I plan on using the OEMs in the Winter
Current: 2009 Nissan GT-R | 2012 Converted | Cobb Tuned | AMS Downpipes | Armytrix Exhaust | AFE Intakes
| Forgestar F14 + Pirelli P Zero 295/305 -- Past: 2011 550i ///M Sport | 2010 M6 Coupe | 2004 BMW M3 Convertible | 2003 BMW 330i |
05-18-2017, 08:50 PM | #39 |
Knees in the Breeze
Rep 22
+1 on the Continentals, I just switched my 5 to those today. I have them on my wife Q5, and they've lasted through some pretty terrible roads here in DC MD VA. As for the ROFs.. never again! I went through 2 sets in two years, replaced 2, twice... Most if not all places will refuse to fix or patch ROFs and for several good reasons:
1) Depending on where you get said loss of pressure... driving on only the support of the sidewall compromises the integrity of the sidewall. Meaning, you are crushing the sidewall making it more susceptible to bubbles or structural separation.. ie a bubble or tit. That alone is not worth the trouble as a repair on such a structurally compromised tire would place liability for any malfunction on the repairer. 2) Most of the shops that you would pull into for emergency repairs will not be equipped to remove the ROF properly or put it back on properly without damaging either your rim or the sidewall. They aren't going to take the chance and either be held liable for any resulting damages to your rim, or issues you may encounter down the road. 3) ROFs are designed to allow you as the operator to maintain control of the vehicle in the event of a sudden loss of pressure..a blowout. The stiff sidewall allows you to safely limp your vehicle to the nearest safe place to stop, not cruise down the highway till you decide you've had enough of that cladding noise. Within a mile or two, yea, but 6+ that tire is toast, and there’s no way of telling just how far you drove without pressure if you pull in with 0psi.. For instance my wife hit a pothole (more like a crater left by a mortar round) on 295 near Baltimore a few nights ago. About 4-5 hours later, when we're leaving the event, I feel that all too familiar ass end bounce coupled with the "thud, dud, thud, dud.." .. My rear end is twerking to the next trap album. On the way home, that tire burst I was able to limp into this Pep boys not to far off the road. Tried as they might, they could not get the tire off the rim..
06 325xi R.I.P "you're in a better place now"
94 JDM DC2 (boost junkie) 12lbs Sun burst orange "PLF and PFL are interchangeable terms when it comes to Holland DZ" -1SG Bailey 319th AFAR |
05-24-2017, 12:46 AM | #40 | |
Rep 237
I had a 3.5" screw through the centre of the tread on my Dunlop winter run-flat. The car was fully loaded with passengers and luggage. I drove on the tire for three days over the Christmas holidays. I went to my tire shop and saw the inside of the tire. The entire inside was shredding and the sidewalls were visibly flattening. The tire was NOT repairable. My second flat was on one of my GY LS2s. Same type of screw through the tread. However, this time I knew better and constantly kept the tire inflated every few gas stations on my way to the same tire shop. Other than the screw there was no visible sign of inside stress and no shredding. That tire looked perfect and was easily repaired just like a regular tire. It was on my car three years. Please note that Canadian F10s don't have TPMS with sensors. They have a FTM(Flat Tire Monitor) which tells you the tire is flat when it has 0 psi. So both tires ran flat. The difference was the distance. The Dunlop for a longer period over a period of days while the GY was only flat for a short time due to the constant fill-ups. So if you have a tread flat, keep the tire inflated and you may be able to save it.
2018 640ix GT; Alpine White, Blk Nappa, Piano; M-sport, Premium (Ceramic, SIRIUS, Soft-close, Vent/Massage Comfort seats, Surround, Sunshades, Parking Ass't), Advanced Driver Ass't (Lane keep, Steering/Lane control, Cross traffic, ACC with Stop/Go), Smartphone, Tint.
Retired: 78 300D, 81 300SD, 87 190E, 88 Porsche 924, 89 260E, 93 300E, 97 Volvo 850, 98 E320, 03 BMW 325iT, 02 C230 Sport Coupe, 08 BMW 535i, 12 BMW 535i X-drive |
05-24-2017, 03:28 PM | #42 | |
Rep 49
Now my f10 feels like new and what bmw should feel like from factory. |
06-05-2017, 12:17 AM | #43 |
Rep 383
Drives: 16 X3 28d/18 540d xdrive
Days after buying my 2016 X3, I had a large puncture in an OEM GY RF. I took it to a local General Tire outlet and asked about possible repair. Before removing tire from wheel, the manager provided a qualified response: depending on brand, some RF are constructed with a dense foam liner designed to help support an underinflated sidewall. Other brands (including GY's) use very rigid sideways instead. The latter design could be patched because there was access to the inner tire and puncture, while those with the foam insert bonded to tire carcuss permitted no access. His response might better explain why some brands of RFs are repairable while others aren't.
Nevertheless, mine are coming off as soon as I can justify cost of conventional-tire replacements. |
06-05-2017, 09:04 AM | #44 |
Dream crusher
984
Rep 2,421
I'm running BF Goodrich G Force Comp 2 A/S on 20" and these are the best god damn tires I've ever owned. 10k miles on the rears and they are still holding like they're brand new. Slight wear. I'm hoping I can see 25k off these things unlike my RF where 10k they were shot. Only down side is ugly sidewall, but well worth the trade off in performance.
IG: @bmwdoubles |
Tags |
tires on your f10 5-series |
