03-11-2020, 08:59 PM | #1 |
Rep 37
Hey guys,
I found a lot of threads on this but I'm still not clear. Need some advice before I spend some money. I bought some wheels from another member. M6 343M 20x9 +32 265/35/20 20x10.5 +19 295/30/20 Michelin PSS Stock m-sport suspension. The front wheels fit nice with 12mm spacers. No rubbing. The rear wheels stick out a lot. Maybe like 2 inches. And rubs. So I need smaller tires. My current rear tires are 275/30/20. Question - will the 285/30/20 fit right or will that still rub? I currently have 18mm spacers with the 275/30/20, but I want wider tires. Thanks everyone in advance. |
03-12-2020, 10:51 PM | #2 |
Rep 72
From the pictures, it looks like the wheel width itself (10.5") may be too wide and contributing to the rub. A 275 is 20mm narrower on the tread width than 295, so that gets you about 10mm closer to the fender (20mm/2). You would also see a little relief from the aspect ratio of a narrower tire, as a 275/30 is lower profile than 295/30. Are you running 18mm spacers in the rear? That's about 3/4 of an inch.
03-13-2020, 08:19 AM | #3 | |
Rep 37
So even the 285/30/20 will rub bc the wheels are too wide? Will 275 fit the wider wheel? These are my favorite wheels, I would hate to have to sell them. |
