2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes M5 Sway bar to 550i?
      06-17-2013, 07:48 PM   #177
45ACP
Long Live the 1911
45ACP's Avatar
Drives: Hooptie
I just installed the M5 sway bar and it took about 2 hours while the car was propped on Rhino ramps since it was a tight squeeze. I'd definitely recommend using a lift if you can get access to one. You'll need an 8mm socket to remove the undercarriage cover screws, a 14mm socket for the frame bolts, and a 19mm open wrench (or adjustable wrench) and T40 bit for the front swing support.
Here's a photo of the 550 non-Msport sway bar (top) vs the M5 (bottom). Upon first glance there doesn't seem to be much of a difference between the two, and I don't have a set of calipers to measure the diameter, unfortunately. However, the M5 sway bar does feel noticeably heavier in the hand.
      06-17-2013, 08:39 PM   #178
528imsport
528imsport's Avatar
Drives: Msport
So after the install how was the ride?
      06-18-2013, 08:23 AM   #179
45ACP
Long Live the 1911
45ACP's Avatar
Drives: Hooptie
I don't know yet, but there's plenty of feedback from others already.
I made the mistake of not test driving before attaching the undercarriage cover back on. The following day I was hearing a lot of clunking noises, and I suspect that I didn't bolt down the front swing supports tight enough.
      06-19-2013, 05:48 PM   #180
ben_ben125
ben_ben125's Avatar
Drives: G37s, 550i ,
I would jus like to clarify does the m5 front sway bar a direct fit to the 550i sedan? Do I need to change the end links? Would the stock end links work.
I also read somewhere that the 650i rear swaybar would fit the f10 what about the f12 m6 rear sway bar will it fit??
      06-19-2013, 07:35 PM   #181
45ACP
Long Live the 1911
45ACP's Avatar
Drives: Hooptie
Helpful tip -- make sure the nuts for the front swing supports are tightened until they don't turn anymore. I was able to tighten the driver's side by an additional half-turn or so and the clunking went away.
The M5 bar can't be more than 2mm thicker, than the stock 550's, but what a difference it makes. The car feels much more planted when turning and cornering now. Definitely a good bang for the buck.
      06-20-2013, 06:30 AM   #182
mikey0120
Philippines
42
Drives: F10 535Xi M-Sport
Originally Posted by remmib View Post
So what model is the rear bar from that you now have fitted?
Did we find out what the rear bar is from yet?
Retired: 2013 F10 535Xi M-Sport
Retired: 2010 E90 335i M-Sport
Retired: 2007 E90 335i
Retired: 2001 E46 330i
      06-20-2013, 11:37 AM   #183
ben_ben125
ben_ben125's Avatar
any info?
      06-20-2013, 12:25 PM   #184
Alan l.
Alan l.'s Avatar
5506
Rear bar info quoted from the other forum by Nison. I just placed my order for the rear bar and won't be arriving for a couple of weeks since its on back order.
Originally Posted by Nison View Post
Confirmed, the M550d/650i 16mm rear sway bar fits!
the sway bar part# is: 33556791932
sway bar bushing: 33556788630 x2
the install only took 25 mins. it's easier than the front since there's no belly pan to remove
didnt have a chance to drive fast enough to test it out tonight, will report back later.
      06-21-2013, 08:59 PM   #185
caldoone
caldoone's Avatar
Drives: 2019 G15 M850i xDrive Coupe
Installed the Front Sway Bar
I had the front sway bar installed by Mark and his talented group at APM here in the Chicago suburbs and they did a brilliant job and the sway is even more brilliant. You notice the difference without a doubt. The bar was installed days before taking it down to the BMW Experience at the Autobahn Country Club in Joliet, IL and was an incredible day of driving fast without the possibility of being arrested or ticketed.
Thanks Mark!
      06-25-2013, 08:51 AM   #186
Andy H.
Andy H.'s Avatar
44
Drives: 2012 535i M Sport
Alan, would you mind letting us know if your rear sway bar parts order, once received, fit appropriately? And if so, would you please restate a summary of the part numbers you ordered with your fitment coments? Thanks Alan.
LIVE FREE OR DIE
      07-04-2013, 03:48 PM   #187
rborgia
Drives: 2015 M4
2015 BMW M4  [10.00]
Ok, I've gone through this thread a couple of times and IMed Joe@ptech (never heard back from him). in any case... I'm unsure of which parts I need. I have a 2011 550i X-Drive M-Sport. I would like to upgrade front and rear bars... Can someone tell me which part numbers I need in order to do so?
Thanks!
Rich
Rich B.
2015 M4 | Alpine White
      07-09-2013, 07:51 PM   #188
joe@ptech
NorCal BMW Specialists
Drives: 17 M2|16 X5M|74 tii
Sorry, we have been out of town the last couple weeks racing in Utah and then this past weekend at Laguna. I've responded to all PMs.
As stated above, anyone can call the shop at any time to order these bars to have them shipped out ASAP. Logan is standing by to take these requests.
925-426-1361
      07-19-2013, 07:38 PM   #189
Andy H.
Andy H.'s Avatar
44
Just received confirmation from getbmwparts.com that my rear sway bar and bushing mounts as follows:
were shipped out yesterday via UPS.
FYI: They had been out of stock for several weeks now. Finally they received shipment from Germany.
Looking forward to this install.
LIVE FREE OR DIE
      08-04-2013, 02:56 PM   #190
Andy H.
Andy H.'s Avatar
44
Just completed the rear sway bar installation. Very easy. Takes 20-30 minutes.
LIVE FREE OR DIE
      08-04-2013, 09:50 PM   #191
528imsport
528imsport's Avatar
Drives: Msport
congrats
Is your car M Sport?
so what the feeling comparing to the stock?
      08-04-2013, 09:51 PM   #192
528imsport
528imsport's Avatar
Drives: Msport
after 3 months of waiting shipping, I installed the front and wow this is a must have if you love driving, it is worth every penny.
The car feels like on rails now, much more planted
      08-04-2013, 10:03 PM   #193
528imsport
528imsport's Avatar
Drives: Msport
Any 1 will install the rear bar on a 528i M Sport?
Love to know if it fits and the feeling
      08-05-2013, 12:27 PM   #194
remmib
remmib's Avatar
Norway
1571
Drives: 2013 F10 520d M-Sport
Reading this makes be want to install it too, but I wonder how it will drive with my KWv3 suspension.
Are you on OEM passive m-sport suspension?
      08-05-2013, 05:37 PM   #195
rmastale
Drives: F10 535i MSport, F15 X5 MSport
Wondering the exact same thing... Anyone on kwv3 coils do this and like it?
      08-05-2013, 09:20 PM   #196
528imsport
528imsport's Avatar
Drives: Msport
it will be hard.
my is ok with M sport suspension just right for HK roads.
      08-06-2013, 12:41 AM   #197
mdrobc13
mdrobc13's Avatar
Drives: Made in Bavaria
2021 BMW X3e  [0.00]
2016 BMW M4  [9.00]
Is a direct fit. Just had my dealer install mine about 2 weeks ago. Car is great now. Still trying to figure out what would work to upgrade the rear sway bar also. See folks are putting 550d/650d rear sways on their cars but it seems that those are mostly 535i guys not 550i owners no? Anybody with intel on the rear? Would an M5 rear sway bar fit?
'22 BMW M4 Comp (SSG/Black)
'16 BMW M4 (Shakir Orange/Black) - gone not forgotten
'15 BMW M3 (Black/Black) - gone not forgotten
'10 BMW X5M (Black/Black) - gone not forgotten
'08 BMW M3 (Space Gray/Black) - gone not forgotten
      08-07-2013, 09:17 PM   #198
Andy H.
Andy H.'s Avatar
44
congrats
My car is a 2012 535i with ACS springs. It handles great! It handles like it is on rails. Lots of fun! I will be receiving my Morr MS8's next week. 20 inch rims - 9 up front and 10.5 in back. Wrapped in PSS 255 up front and 295 in the rear. Recently installed the Eisenman quad race exhaust with black tips and the M sport quad diffuser. It has the 3D design front lip spoiler and the M5 rear spoiler. The car is black sapphire metallic with the msport body package. I'm waiting for the wheels. Once received, I'll post pics.
LIVE FREE OR DIE
