2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Help!
      12-19-2011, 05:03 AM   #1
joeh9290
Drives: 2011 BMW 535i
Help!
On my 535 I have the cold weather package and it comes equipped with the headlamp washers. How does that work? The on board manual isn\'t very helpful
      12-19-2011, 06:46 AM   #2
vdubturbo
Drives: E90, E36, 997
According to my salesman, the activate when you use your windshield squirters and your headlamps are on. So if your headlamps are on, you get both windshield and headlight wash. If they're off, just windshield.
      12-19-2011, 07:46 AM   #3
wang133ro
Drives: 535d F10
That's correct. Also, the headlamp washers don't activate for EACH windshield wash, even if the lights are on; I think there's a time interval that has to pass before your activating of the windshield squirters will also activate the headlamps washers again; presumably to save liquid.
Though I had no idea this is related to the cold weather package.
      12-19-2011, 09:26 AM   #4
AVIMAX
Drives: last BMW was 2014 535xd
If your headlights are on, the headlight washers will spray every 3rd time you spray the windshield starting with the first spray. You can't miss it, if you are standing still, the whole front of the car will get sprayed. I wish this feature had a button to activate rather than automatically. In the summer, the headlights don't need spraying, but at night, if I want to clean the dust from my windshield, I have to turn off the headlights to avoid having the whole front of the car sprayed.
      12-19-2011, 10:12 AM   #5
vdubturbo
Yep. Especially sucks if you just washed the car.
      12-19-2011, 12:51 PM   #6
islandnipper
islandnipper's Avatar
Drives: MY 2012 F10 520d SE
Your dead right! Somewhat ruins the effect...
Washers are made automatic, probably to ensure that drivers wash dirt off the headlamp covers often enough and not deliberately avoid having the front paintwork splattered with washer foam.
I believe that given time, xenons can cook grime into the surface of the covers, leading to significantly degraded performance. Presumably that's why some countries (if not all?) make washers a legal requirement when xenons are fitted.
