2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications BPC N63 Non TU Flash tuning coming soon
      12-04-2017, 11:56 AM   #45
135i_vs_
135i_vs_'s Avatar
Drives: M5, 135i, 335d, F10 550xi
Purchased on Black Friday, still need to get you guys the DME.
Haven't seen any online testimonials yet, guess i might be the first?
      12-04-2017, 12:14 PM   #46
Bob@BPC
Bob@BPC's Avatar
Drives: F30 328i Sport Line
Originally Posted by Teddylongtooth View Post
Are these dyno numbers (before and after) with or without correction factor?
I looked at the this again morning and I see in the upper right corner CF SAE, so duh!! Yes its with correction factor. I answered my own question.
Yes, they are corrected, but the pull was done on the same day and on the same dyno, so the gains are the same. I can post uncorrected numbers if you would like, Im sure it made more uncorrected.
We've done a few local already, not sure if they are on the forums.
FSociety3812.50
      12-04-2017, 12:21 PM   #47
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Drives: G80 M3, X4M, G07 X7m50
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
Looking forward to seeing Uncorrected and STD for giggles
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      12-07-2017, 07:02 PM   #48
135i_vs_
135i_vs_'s Avatar
Bob@BPC please tell me For N63 you can do OBDII port flash? I didn’t pull the DME yet. Saw you post about it for the diesels
      12-08-2017, 10:29 AM   #49
535_BiTurbo
Drives: 2012 550I - BMS Stg 1 & CAI
Stage II has timing, fuel and boost adjustments and downpipes are required for the tune upgrade. Power gains will be around 40 -50rwhp more than stage I.
Why are downpipes needed with stage 2?
      12-08-2017, 12:40 PM   #50
Bob@BPC
Bob@BPC's Avatar
No, only the MEDV17.x & EDC17CPXX DME/DDE have been cracked on the Fxx cars. As of right now, You still need to unlock a bootloader on the MSD85.x
The exhaust housing & the manifolds on the non tu turbos are on the smaller side, too much backpressure can lead to some bad things happening to your connecting rods. But if you want to take that risk, we can do a stage II tune with the stock cats in place and just lower boost down low.
      01-19-2018, 09:23 AM   #51
135i_vs_
135i_vs_'s Avatar
Bob@BPC Please note your website now says "remote tune purchase procedure & time line". Does this mean you can do it remotely now?
I purchased the tune already on Black Friday, but haven't had the chance to send it the DME.
Oh, might want to fix the hp..says 93hp gain..
https://bimmerperformancecenter.com/...x-stage-1-tune
      01-19-2018, 02:26 PM   #52
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
Just did one, already have a tune out for the X5m We can flash e70/e71 over obdII with out need to unlock them.
I'm currently running a stage 2 tune by Halim from HCP. You mentioned on this thread about BEF only for those with JB4, which I am running a JB4 as well. Do you have advice on how I should do this...just keep stg2 & JB4 or should I run a BEF & JB4? Trucks a monster up to 21psi, but I'll get overboost codes anytime I go over and it'll fall on it's face (no throttle input, bogs, etc) until I reset the code. I've read aboutabout N54/S63TU guy swapping to a 3.5bar sensor but Halim says that doesnt apply to thethe S63...nevertheless I've considered replacing the sensors just in case.
Current mods:
Custom intake
Gutted stock downpipes
NGK 97506 gapped to.22
HCP stage 2 flash
JB4 with meth running dual CM7 but I'm not running meth yet
Mods waiting to be installed:
S63TU headers
Wrapped aftermarket catless downpipes
X-pipe
Muffler delete being replaced withby Vibrant resonators
GFB+ maybe?
      05-15-2018, 11:37 AM   #53
135i_vs_
135i_vs_'s Avatar
Bob@BPC , another DME MSD85.0 on their way to you via UPS. :-) Looking forward to more power!
      05-15-2018, 02:54 PM   #54
warpeacelove
Drives: 550i
Did you proceed with the Stage 2 Tune and How much PSI does the tune produce?
      05-16-2018, 06:38 AM   #55
135i_vs_
135i_vs_'s Avatar
Going with Stage 1. The car currently has all stock components.
      05-16-2018, 09:10 AM   #56
warpeacelove
Drives: 550i
How PSI does your stage 1 gives at Bob@BPC
      05-16-2018, 09:11 AM   #57
warpeacelove
Drives: 550i
THx
