2010 2011 BMW 5 Series Forum F10 Battery replacement gone wrong! |
06-11-2020, 04:29 PM | #1 |
Rep 31
Today I was replacing my battery and while putting the new one in I over tightened the positive clamp and broke the nut
I'm gonna get one from the junkyard since the dealer want me to buy the whole cable. However, I need to know how to get the red plastic cover out? |
06-11-2020, 06:02 PM | #2 |
Rep 96
I’m not sure how serviceable the “safety” terminal is. It actually has a small explosive charge within that detonates in the case of an accident to sever the current to the starter/alternator.
2014 535i xDrive | MHD Stage 2+ | ER Catless DP | ER Charge Pipe | G-Plus Intercooler | Walbro 450 LPFP | Staggered 20” Avant Garde M359 |
bimmer_mods16.00 EL Jeffe 5612.50 |
06-11-2020, 06:03 PM | #3 |
Rep 659
Not made to come apart.
Bite the bullet and learn the lesson. |
bimmer_mods16.00 |
06-11-2020, 08:30 PM | #5 |
Rep 834
That part in your picture is available (clamp bolt and nut for your battery terminal) all over the internet for $5 up to $10.....and in your original picture, it looks like your clamp bolt broke, not the nut, but even if you did break your nut, all is included for $8 (average price)
Example on Amazon.... |
bimmer_mods16.00 |
06-12-2020, 02:04 AM | #6 | |
Rep 31
However, I'm having an issue getting the clamp loose of the red plastic so I can get the broken nut out. |
06-12-2020, 08:23 AM | #7 |
Rep 452
Have you tried a press? Might be pressed in
bimmer_mods16.00 |
06-12-2020, 10:06 AM | #8 |
Rep 5
I did the same thing. Left it as. That was about three years ago.
Bruce
__________________ 2013 F10 535i | 6 Speed Manual | M Sport Package | Santorini Blue | Black Nappa |
bimmer_mods16.00 |
06-12-2020, 02:43 PM | #9 |
Rep 31
This is a picture of the clamp from the bottom and the broken nut is located within the circle border
06-12-2020, 02:50 PM | #10 | |
Rep 31
As seen on this picture taken before I broke that nut |
06-13-2020, 07:04 AM | #11 |
Rep 452
bimmer_mods16.00 |
06-13-2020, 09:35 AM | #12 |
Rep 1,254
I can't help you with your question but in future here is one tip
when you tightening clamps on battery tighten until you feel resistance then tighten quarter of turn you should be good
bimmer_mods16.00 |
06-20-2020, 08:36 AM | #13 |
Rep 31
*****PROBLEM SOLVED*****
Just an update about how I ended up dealing with this! I've got it fixed for only $5! In case anyone running into the same issue, all you need is to get a new nut, you don't need to buy a new cable for $$$. I got a used nut off a negative terminal from the junk yard. I had my cable taken out from the car, set it on a table and used (pry tool & small screw driver). I decided to get it out from the red plastic/rubber underneat it by squeezing the screw driver to get into the top side of the nut so I can push it up and used the pry tool to left up the red plastic/rubber just a little enough to have a room for it so I can pull it out! You don't need to cut or damage the red plastic/rubber. It's quit frustrating but relatively easy. Got it out and put in the one I got in the same way but also used a small hammer in the final stage to get It pushed in. Installed the cable back to the car and connected my new batter and everything worked just fine. Thank you guys for the input! I really appreciate it! |
06-20-2020, 09:21 AM | #14 | |
Rep 1,254
Glad it worked out for you No better feeling than fixing something and saving $$$
