2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding Rear Backup / Top-View Camera Distortion
      02-25-2013, 12:09 AM   #1
dbs600
Drives: 2011 750LXi Individual
Has anyone else seen this problem, where the rear backup / top-view camera has a large white spot?
It’s not ambient light from either the car or street and I’ve cleaned the lens, but the spot remains…
      02-25-2013, 06:52 AM   #2
Breach
Drives: F10 520dA M Sport
Make sure your rear view lens is indeed clean and is not scratched.
      02-25-2013, 01:53 PM   #3
OzDriver
OzDriver's Avatar
Australia
Drives: '13 535i & '08 530i
Faulty areas on CMOS camera sensors show up as white, so the camera may be damaged.
Alternatively, an infrared source can also show up as a white patch on the display. Is there anything hot nearby, or something that may be emitting/reflecting IR?
      02-25-2013, 02:36 PM   #4
dbs600
Thanks for your reply, but no, nothing hot or emitting/reflecting infrared.
I see this all the time, not in any particular area...
      02-27-2013, 03:27 PM   #5
Zaman
Zaman's Avatar
Drives: 2012 BMW (F10) 528i Xdrive
JUST A GUESS
Do you have a similar problem when you put it into reverse and just seeing the rear camera?
If yes, it is possible that your rear camera lens is slightly rotated toward the right and showing the reflection from the plate illuminator on the side of the plate housing. To test put two similar objects with equal l distance from the center line and see if the right one appears closer to the center.
BMW F10: A formula to captivate the senses.
2012 528i XDrive Alpine white
