12-28-2015, 12:29 PM | #1 |
Rep 140
Question on sway bars
So I have a 2013 M Sport RWD. It has the M Sport suspension. Does anyone have experience with adding after market sway bars with stock suspension. How much will they reduce body roll?
Thinking H&R or Eibach or turner |
12-28-2015, 02:01 PM | #2 | |
Rep 14,522
http://f10.5post.com/forums/showthre...light=sway+bar http://f10.5post.com/forums/showthre...light=sway+bar http://f10.5post.com/forums/showthre...light=sway+bar http://f10.5post.com/forums/showthre...light=sway+bar
01-11-2016, 06:04 AM | #4 |
Rep 1,873
In my experience the M5/650 route on my 535 was pretty easy, removed a bunch of slow swaying body roll, but increased under steer noticeably. There is a post in one of those threads from me before I purchased where I did a little math and figured that might happen. I'd like to get an aftermarket bar larger than the stock 650 bar....
01-16-2016, 10:10 PM | #5 |
Rep 342
I am going to hijack this thread a bit but same topic... I just bought a black/black 2013 535i cpo yesterday with 37k, M sport, premium, technology and cold weather packages and I am looking for a few upgrades as I am coming from a E90 335i with a JB4 and DCI. Tint, new Sways and a tune are first up.
Looking at the info I can find, the H&R set uses a 30mm front and 20mm rear sways, but is kind of pricy. The M5 front is reported at 29mm (but I saw a pic from a link above with calipers measuring it at 26mm?). The 650 rear sway is 16mm (?). What sizes are the stock F10 M sport sways? Anybody tried the M5 front (which is reported to create understeer) with the 20mm H&R rear to make it more neutral to oversteer? If so how does it drive with this combo? Should I need to change the end links front or rear with these sets? Just wish the 2013 had sport seats like the 2012 I test drove... |
01-16-2016, 10:19 PM | #6 |
Dream crusher
984
Rep 2,421
I did the ECS sway bar kit which is the M5 front and 650i rear. I did the rear first and there was a noticeable difference in body roll on turns. Put the M5 sway in a few weeks later and no noticeable difference. So if you go oem I would say only do the 650 rear. If you do the front go bigger than M5 sways.
IG: @bmwdoubles |
01-17-2016, 12:19 AM | #7 | |
Rep 494
The M5 FSB is 26mm. Most guys I've seen go with the 16mm 550D/650i RSB so you get a 2mm increase for the front and rear.
01-17-2016, 05:18 AM | #8 | |
98
Rep 305
01-17-2016, 11:26 AM | #9 | |
Rep 342
Does anyone know about the H&R sways? Is their FSB really 30mm in the middle or is it similar to the M5 FSB where it is a smaller diameter in the middle? If it is also smaller in the middle what is the real diameter? Since this is just a big torsion bar it is that middle diameter (not the ends) that controls how (twisting) stiff it is. |
01-17-2016, 11:57 AM | #10 | |
Rep 494
Here's a post from the M5 board explaining the difference between the stock M5 bar and the M5 competition pack bar. http://f10.m5post.com/forums/showthread.php?t=946237 |
01-18-2016, 06:35 AM | #11 | ||
Rep 1,873
