2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Spacers for 550 xdrive
      03-23-2014, 08:20 AM   #1
jackass
Drives: M5, 911 Turbo s
Hi Guys, I have a 2013 550 m-sport xdrive with stock suspension and stock wheels 19" 245. I was thinking of installing 10mm spacer in the front and 15mm in the rear, what do you think? Will this setup affect the xdrive system?
      03-23-2014, 09:01 AM   #2
ferrarif1
Drives: F85, G05, E46M3
no impact on the x-drive system. Others have done a similar setup and you can measure yourself to confirm using a straightedge from the wheel/tire to the lip of the fender.
      03-24-2014, 04:21 PM   #3
VMRWheels
VMRWheels's Avatar
2038
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
How far in or out won't really affect the x-drive system. What will mess up your diff is when your front and rear tires are different heights. Adding spacers shouldn't be an issue.
      03-24-2014, 04:33 PM   #4
Dan1416
Dan1416's Avatar
39
Drives: 2013 528 x-drive
Won't affect your xdrive, but if you're lowered I'd recommend 12mm front and 18mm rear. Much more flush.
