02-02-2023, 09:51 AM | #1 |
Rep 2,485
F10 Headlight Questions
Hi guys. I am fighting the condensation problem with one of my headlight units. Two questions: Do these units have a drain? And what is the function of the two white things in the photo below?
Edit: I attached the jpg. I can't get it to display in the post. Thanks guys.
2006 E90 330i (retired)
2009 E90 335i (retired) 2012 E70 X5 50i M Sport (retired) 2016 F10 535i M Sport Last edited by SteveMD; 02-02-2023 at 09:58 AM.. |
02-02-2023, 10:25 AM | #2 |
Rep 199
condensation is known and normal on these headlights. But if that condensation is covering the good center part of the light then there is issue. Around the edges is all okay.
02-02-2023, 11:34 AM | #3 |
Rep 2,485
I completely understand. I have the issue in a major way.
2009 E90 335i (retired) 2012 E70 X5 50i M Sport (retired) 2016 F10 535i M Sport |
02-02-2023, 08:45 PM | #4 |
Rep 1,261
Repair service on eBay to repair seal…fix it before it’s too late..cheaper than new light
StradaRedlands4943.00 |
02-23-2023, 01:48 PM | #6 |
Rep 11
I also just bought a F11 and the guy selling the car told me I shouldnt worry since it's to be expected. I didnt want to trust this but other people told me its even mentioned in the manual that this is a normal behavior of the headlight
02-25-2023, 09:05 AM | #7 |
Rep 1,126
Take out headlights. Remove all modules. Rinse the inside of headlights with distilled water. Let it dry. Apply good clear silicone in gap where clear lens meet the black housing. Don’t need to take apart lens.
02-27-2023, 06:14 AM | #8 |
Rep 2,485
That's what I don't get. If those are open to the air, how does sealing the headlight fix anything.
02-27-2023, 08:12 AM | #9 |
Rep 1,356
It is designed to vent out. All headlights have vents. Bulbs produces heat and it needs to breathe. If you don’t seal, a lot more moisture will come in and destroy your modules then you will have an expensive repair
04-15-2023, 03:01 PM | #11 |
Rep 1,356
10-30-2023, 09:37 AM | #12 |
Rep 97
My F10 is now literally a fish bowl. Water got inside and when the shop removed it, the water drained from those two white things plus from the electrical connection port on the headlight. not sure what is the best plan to go through now since I really dont want to spend 1k$ on a new driver headlight assembly...
10-30-2023, 11:14 PM | #13 | |
Rep 831
Post #2 provided the answer.....and I had a bad leak in the corner of the lens, drained out the water, sealed the edge of the lens to the black housing, and all is good....no leak through rain or car washes for the last 10 months.... https://www.bimmerfest.com/threads/f...#post-13783925 |
11-02-2023, 05:33 PM | #14 | |
Rep 97
Found a nearby wreckyard with 2 clean OE BMW headlights asking for 1300$ for the pair with everything inside of them included and it seems like I'm heading that way. Why get a pair when only one is damaged? because the one left is Hella branded which I know OEM but I want the pair to match in terms of brand (I know OCD much? lol) but moreover in terms of condition. I would hate it to have one light looking slightly yellower than the other or the light beam itself is different shade because of the difference in age. Plus in that case I would have one spare headlight assembly with everything in it just in case. |
