2010 2011 BMW 5 Series Forum F10 Click when engaging brakes |
10-22-2023, 10:06 PM | #1 |
Rep 335
I know I'm beating a dead horse here but my brakes used to make a single click when engaged and the dealership told me it's a common thing on F10 since the pads move back and forth depending on the direction of travel when engaging the brakes. A couple months ago they replaced my brakes and rotors and did not hear the click for a while, now it's back.
Is there a remedy for this? Is there something I can do about it? My dealer does not seem to find it to be a big deal but it bothers me. |
10-22-2023, 10:44 PM | #2 |
Rep 111
I recently installed aftermarket Bosch brake pads on my X5, and they quickly developed a click on first braking after changing direction on both sides. I changed the brake pads to a different brand and noticed that the Bosch brake pads (mine) had a backing plate that is not attached to the brake pad. It is just clipped on.
The new pads have a backing plate that is fully attached. Clicking is gone. Nb: the first original pads that came with the vehicle did not click. |
10-23-2023, 07:11 AM | #3 | |
Rep 335
10-23-2023, 07:55 PM | #4 | |
Rep 111
The dealer is not concerned with it because: 1. It's not his car 2. It will cost him time/money 3. It's not a safety issue I would go back to the dealer and complain that it is not normal and is not as designed. If he tells you that it's normal then ask him to take you out in a demo vehicle to demonstrate the all vehicles do it. |
zvery777271.00 |
10-24-2023, 07:49 AM | #5 | |
Rep 335
ChiltiCoatl891769.00 |
10-26-2023, 04:23 AM | #6 |
Rep 639
It’s a common thing from what I’ve read. I first noticed it on my 5 series after switching to Akebono pads. They appear to be just slightly smaller or “looser” in the bracket that holds them in place, allowing the sound to occur when first changing direction. This only seems to be an issue in the front.
I swapped to genuine pads and the sound mostly went away. But since then it has come back, and it appears the bracket itself has worn in the area where the pad is held in place. I’ll be replacing the pads and the brackets together next time I do brakes to hopefully remedy the issue. TLDR: Maybe try having the shop swap the mounting bracket for the front pads. |
zvery777271.00 |
10-27-2023, 08:13 AM | #7 | |
Rep 335
10-28-2023, 06:39 AM | #8 |
Rep 435
Drives: 2016 F10 BMW 535i M Sport
I look forward to hearing what they have to say, I am performing my Rear Rotor replacement, and front and rear brake pads, and I am curious as well if after awhile I will hear this clicking noise.
zvery777271.00 |
11-08-2023, 12:28 PM | #9 |
Rep 335
Update: About to pick up the car later today and here is what they did to hopefully get rid of the noise.
FRONT CALIPER BRACKETS AGING INSPECTED BY SFTS AND TSE MILLER. THE AMOUNT OF MOVEMENT BETWEEN THE PAD AND THE CALIPER BRACKET IS EXCESSIVE. THERE IS A SMALL NORMAL AMOUNT OF NOISE THAT WILL OCCUR WITH LOAD REVERSAL WHEN BACKING UP AND THEN GOING INTO DRIVE BUT THE CUSTOMERS CAR HAS AN EXCESSIVE AMOUNT. REMOVED THE PADS AND CALIPER BRACKETS AND INSPECTED, CLEAN PADS AND LUBE, REMOVE AND REPLACE THE CALIPER BRACKET AND PAINT TO MATCH AND TOUCH UP THE CALIPERS AND RETAINING SPRING. INSTALL NEW HARDWARE AS NEEDED AND PERFORM ROAD TEST. PULLED FAULTS AND NO FAULTS STORED FOR CHASSIS OR ENGINE SYSTEMS |
11-08-2023, 03:20 PM | #10 | |
Rep 504
Drives: 2013 BMW F10 N55 535i XDrive
$ PURE STAGE 2 {} JORDAN CUSTOM TUNE {} DORCH HPFP {} SNOW METH {} DINAN EXHAUST {} EVOLV DARK OLIVE WRAP $
11-09-2023, 05:20 PM | #11 | |
Rep 111
Did this fix the issue? So, did they replace the caliper brackets with new ones? How much did this cost?
11-13-2023, 09:18 PM | #13 |
Rep 1,038
Did not notice this on my F10 before upgrading the front calipers, but this exact problem happened on my Wife’s E90. Bosch Blue Ceramic brake pads, click when changing direction. Pads are slightly shorter than OE.
I bent the springs that engage the caliper piston ti bias the pad for braking from forward direction, they don’t click anymore. I also noticed her caliper brackets are rusted and worn where the pad hardware sits. This is Canada, lots of salted roads, 220k kms later the brackets are corroded. I will probably replace them the next time I do the brakes. |
zvery777271.00 |
