2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Do you guys see this on your idrive?
      02-16-2020, 12:53 PM   #1
BMW FOREVER
BMW FOREVER's Avatar
Drives: 2014 535i Xdrive
Hi Guys, I have a 2013 F10 with NBT and my car is equipped with the driver assistance package. Can I check if you guy see the below pics on your idrive screen when the individual features are activated?
guys with MY 2013 (Pre-LCI) please chime in. Understand 2012 and below wont see it as they have the CIC version.
      02-16-2020, 04:39 PM   #2
Surly73
Drives: '11 535xi 8AT KWv3 MPE MHD xHP
What's the actual question? You think you should see those pictures and don't on your car?
I believe that there is a single check box setting which disables the full screen display of "driving modes" on CIC/NBT such as NORMAL, COMFORT, SPORT etc.... That same check box (or a similar one) may enable/disable full screen flashy marketing graphics for the driver aids too. If you are expecting these and not seeing them, it could be this setting.
      02-16-2020, 07:29 PM   #3
BMW FOREVER
Yup I’m not seeing them on the car and not sure where to enable them. Was wondering if this is a NBT vs NBT Evo thing...
      02-16-2020, 08:11 PM   #4
wcr3d
Drives: 2013 535i XDrive M Sport
My understanding is your car has CIC, NBT came with LCI.
Someone with more understanding may correct me if I'm wrong.
      02-16-2020, 08:17 PM   #5
cdmulders
cdmulders's Avatar
Drives: 2013 535xi
NBT came about 1 year before LCI, +/-. My F10, built in August 2012, has NBT.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension
2000 528i, Cosmo Black, beige interior, Sport package (retired)
      02-17-2020, 12:26 AM   #6
BMW FOREVER
Hi, so does your vehicle display these screens?
      02-17-2020, 09:01 AM   #7
Qsilver7
Qsilver7's Avatar
Drives: F06 650ix GC / F15 X5 50i
Which button set-up do you have to initiate the intelligent safety features? Do you have the switch on the dash to the left of the steering wheel (see pics below)? Or do you have the Intelligent Safety Button which is usually a dual button with the HAZARD switch that incorporates all of the safety features into one button that usually calls up the iDrive screens you posted in your original post?
If you have the switch below that turns the safety features on/off...then you won't have those iDrive screens.
button layout can vary depending on how the car is optioned: blind spot|collision warning|lane departure|night vision|head-up display
If you have the single Intelligent Safety Button shown below...that allows you to select ALL or only the ones you want turned on...then you will see the iDrive screens you posted above:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral.
      02-17-2020, 09:13 AM   #8
Qsilver7
Qsilver7's Avatar
Here's some videos that shows & explains how the different BMW Intelligent Safety switrches or (singular) button works:
Video shows how the (older) multple button switch works:
Video shows how the (newer) singular button operates:
      02-17-2020, 09:20 AM   #9
BMW FOREVER
Thanks for the information! However, if you notice, the pictures I have shared clearly shows that intelligent safety button is not present below the hazard button. The F10 never had intelligent safety button there...it only had them next to the steering wheel. Vehicle in the pictures I have shared is a F10.
      02-17-2020, 09:25 AM   #10
Surly73
I keep feeling like we're getting off track. The question isn't how to turn the features on or off, or whether the OP has CIC or NBT, it's why the information doesn't pop up full screen when the buttons are pressed.
On CIC there is one setting which disables all of this "full screen display" when changing driving modes. It applies to DSC/DTC, and SPORT/COMFORT, and may also apply to the extra driving aids.
I suspect that NBT may have the same (since I have turned it off on loaner cars with NBT and NBT evo). If this has been unchecked on the OP's vehicle, it will suppress all the full screen mode change indications that he/she is seeking.
Bottom line: it is an owner option to turn them off. It's almost certainly simply a matter of finding the setting and turning it on if you want them.
      02-17-2020, 09:27 AM   #11
Qsilver7
Qsilver7's Avatar
See the videos in post #8...hopefully they will help explain how to pull up the screens in iDrive to make adjustments for the older set-up.
      02-17-2020, 09:29 AM   #12
Qsilver7
Qsilver7's Avatar
Good point.
      08-12-2020, 04:21 PM   #13
addy27
Drives: F10 550i
I've retrofitted the NBT in my car from a CIC and the images for Lane Departure warning and the Front Collision Warning are there, but when I press the lane change warning button to turn it on, the image (last image in the initial post) does NOT show up.. Wondering what could be the reason since the car the NBT came from had this option also..
Anyone know the coding parameter to enable this?
      08-13-2020, 07:40 AM   #14
Pierre Louis
Drives: 2016 535d
For those of us that hate acronyms and are new to this tech, here is a post that explains it well.
