07-26-2020, 04:37 PM | #1 |
Rep 1
F10 Carplay
Hi, I have 2012 f10 with a cic system, and my friend has an older bimmer tech cp-bm12 Multimedia Interface, now the lvds plugs are showing 6 pins, and my system is 4 pin, is there a way I have rewire this to work, or is it worth getting a cic mmi?
07-30-2020, 09:00 AM | #3 |
Rep 418
You'll save a lot of money and get same functionality as bimmertech by getting Android based unit https://www.android-car-dvd.com/prod...35143168819363
you can find them for even less (between $220-$240) on Aliexpress And you'll get a touchscreen. I think bimmertech unit is using original screen |
07-30-2020, 09:14 AM | #4 |
Rep 1,589
I don't recommend going aftermarket unless you really don't care about qulaity. The quality will not be up to BMW standards. All of these units are cheap and made in China. I had something similar in my E39 and the processor that they use is so slow and does not work as intended a lot of times. I compare it to seeing Youtube reviews when someone buys a knockoff Iphone or Samsung phone, where they make the presenation look nice in pictures, but once you get it, you wish you never had ordered it.
I had Bimmertech on the NBT, but sold my unit as I was not happy with the quality of the picture for $600. I finally ended up going NBT Evo ID6 and it is probably my favorite mod I've done to the car as it's something I use every day. The picture is sooo crisp and clear, much better than my wive's 2018 Q5, which was good to begin with when it was introduced. Not to mention you get touch screen and BMW quality. |
07-30-2020, 10:15 PM | #5 | |
Rep 418
I agree that NBT Evo is the best, but there is also the question of cost, $220-$240 for Android based system, $650 for Bimmertech MMI and Bimmertech sells NBT Evo retrofit for F10 for $2,200 |
07-31-2020, 12:44 AM | #7 | |
Rep 2,591
https://f30.bimmerpost.com/forums/sh....php?t=1675929
2015 BMW 535xi
07-31-2020, 08:19 AM | #8 | |
Rep 1,589
Ended up upgrading to Cermaic I-drive controller which I'm not including in the cost as it was not needed, but I wanted to have it match the rest of the interior. |
08-01-2020, 08:11 AM | #9 |
Rep 14,522
i really need to update my tiny 6" screen. so much info out there as to which way to go
OnlyGerman363.50 |
08-04-2020, 10:55 PM | #10 |
Rep 193
I need to replace my screen and I feel overwhelmed on where to start! Idk if I should just replace it or replace it with an upgrade.
I do know, however, that I'm not a fan of the G30 screen. It looks really outta place. |
08-04-2020, 11:30 PM | #11 |
Rep 418
08-04-2020, 11:31 PM | #12 | |
Rep 418
08-05-2020, 09:06 AM | #14 |
Rep 2,591
Quick update for those interested. Forums members over at the F30 side managed to basically unlock the software DRMs that the manufactures have started placing. You can buy the Aliexpress units and run the Bimmertech software on it now, along with other various improvements, via custom firmware.
2015 BMW 535xi
08-05-2020, 10:36 AM | #15 |
Rep 1,261
lsturbointeg9158.50 |
08-05-2020, 11:43 AM | #16 |
Rep 14,522
Do you know which app would allow me to code this? Carly?
08-05-2020, 12:12 PM | #17 |
Rep 2,591
Bimmercode can.
2015 BMW 535xi
OnlyGerman363.50 lsturbointeg9158.50 |
08-05-2020, 02:56 PM | #18 | ||
Rep 193
08-05-2020, 03:25 PM | #19 |
Rep 1,261
Definitely bimmercode via expert mode but this info was from the f30 forums, have not seen anyone with f10 do it.
08-09-2020, 11:59 AM | #20 | |
Rep 418
"After replacing the screen you need to code the following values: HU_NBT > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480 HU_NBT > 3001 EXBOX > DISPLAY_VARIANTE = breites_display" |
