2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions 2014 535xi lED adaptive headlights
      10-24-2022, 05:46 PM   #1
Darren Doran
Drives: BMW 535ix bmw 540ix
Hey guys I don’t typically ask for help but I really need some. I had a flickering headlight. I took the light assembly out & installed a new driver & ballast. The light works now but one pod in the led is not coming on. I did switch the headlights & the same led is out. So basically I have one light with half power. Thinking it was a bulb I pulled the fan motor inside & went huh…. No bulb to pull it appears Not to be replaceable? Has anyone dug this deep & know if the entire led is built in & is unserviceable?
Thanks in advance!
      11-02-2022, 01:43 PM   #2
Hellboy550i
Drives: BMW 550i
Thanks in advance!
i didn't fully understand the issue but , usually when u change to LED you have have to code the vechicle by bimmercode to make bmw understand that its led and not halogen , thats the solution for flicker,
      11-02-2022, 08:39 PM   #3
Hoa
The actual Low and High beam are one unit with the housing. As far as bulbs, you can only replace cornering and turn signal on the LED headlight.
