2010 2011 BMW 5 Series Forum F10 BMW F11 530i 2013 coolant top up? |
12-16-2022, 09:40 AM | #1 |
Rep 2
Hi,
Can someone please point me to where to check the level and if necessary top up the coolant level on my 2013 BMW F11 530i? I searched online and the engine layout of all the examples I've found differs to mine (I have attached an image of mine). Thanks! Tony |
12-16-2022, 08:28 PM | #2 |
Rep 3,020
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
100% a guess, but up near the (U.K.) passenger side hood strut, right by the cowl?
2:00 position in the photo above. Do you have an owner's manual to flip through, it will be in there. |
12-17-2022, 10:42 AM | #4 | |
Rep 3,020
FYI Benson1970, washer fluid needs a new cap, and it looks like your valve cover or VANOS seals (probably both) are leaking at the front of the engine. Better check the oil filter housing and oil cooler gaskets while you're at it... they're probably leaking as well. Is this a new vehicle for you? Have fun! |
12-17-2022, 01:48 PM | #5 |
Rep 2
Thanks, the top right cap does indeed say "Do not open when hot" so I assume that’s it. I’ll double check when I get home and have access to the manual (away at present).
StradaRedlands4953.50 |
