2010 2011 BMW 5 Series Forum F10 PLEASE help on ET Values |
12-07-2016, 03:13 PM | #1 |
24FITcoach
32
Rep 76
I have a 2014 BMW M550d xdrive touring F11.
I would like to put 9x20" wheels front with 245/35/20 and 10.5x20 rear with 285/30/20 it has to be 9 front and 10.5 rear since the wheels i want are only in this width available for series 5 in 5x120. I'm clueless on the ET values. I want a staggered setup and the whees nicely wide but no rubbing. I will lower the car on springs (eibach or ACS or H&R) nothing extreme, just nice lowering. Can i please have advice on ET values ? From what i read i would need F: 9x20" ET30, 245/35-20 R: 10.5x20" ET45, 285/30-20 Some say 255/295 but others say that will rub and 245/285 is better. Are the ET values correct? Thank a 1000x to those who can help me so i don't order the wrong ET. I would like to work without spacers. Greetz Thietje |
12-07-2016, 04:02 PM | #2 |
Rep 544
I have H&R sport springs and my factory 464M wheels are 20x8.5 et33/20x9 et44. I have 10mm spacers up front and 20mm in the rear with no rubbing and I'm flush all the way around.
My new wheels are 20x9 et35 245/35-20 and 20x10.5 et38 285/30-20. I intend to run 10mm/15mm spacers on these as well and don't anticipate any issues. I recommend you get spacers for a flush look. 10mm front and 20mm rear should work. You want an overall offset of ~25 front and rear.
Project Gamma Intakes / Project Gamma Catless Downpipes / Muffler Delete / DME Stage II Tune / H&R Springs |
12-07-2016, 10:08 PM | #3 | |
Rep 354
Drives: 2017 F80 ZCP MW/SO
you can run your front a little more aggressive probably by another 5-8et your rear you go to 32-34et
Current: 2017 F80 ZCP MW/SO @EnzoRacing PTF BM3 STG 2 GTHaus Meisterschaft GT2 Exhaust SSR Intakes
Swift Springs @drivingwithbenny |
12-08-2016, 02:25 AM | #4 |
24FITcoach
32
Rep 76
Thx all for helping out,
I found these with pictures ... What ya think? Recommended Fitment for the F10 5er. 20x9.0 ET20 20x10.5 ET42 245/35/20 285/30/20 I would say ET25 in the front would be better and i'" surprised the ET42 in the rear looks very flushed on the pics http://f10.5post.com/forums/showthread.php?t=557224 |
12-08-2016, 08:10 AM | #5 |
Rep 14,522
OP no need to run spacers if you get the right offsets for new wheels unless you're planning on using your stocks
12-08-2016, 08:13 AM | #6 |
Rep 544
True @[lsturbointeg], but the wheels he found are et45.
12-08-2016, 08:28 AM | #7 |
24FITcoach
32
Rep 76
After reading numerous topics i think i will go for
Front 255/35/20 9x20 ET30 Rear 295/20/30 10,5x20 ET42 I don't like stretched tires on rims and still want to take passengers without rubbing |
12-08-2016, 02:14 PM | #8 |
Rep 29,202
Sounds like a good fitment, the fronts could be slightly more aggressive, but it depends how low it is.
