12-23-2015, 05:21 PM | #1 |
Rep 7
Sport vs. Sport?
Quick check. Is Sport program activated via center button = Sport program activated via center selector lever push to the left? Exact outcome? Thanks.
12-23-2015, 07:03 PM | #2 |
Rep 4,048
I believe that the Sport setting via the center console button changes the weight of the steering, throttle sensitivity and transmission shift points.
Moving the shifter to the left only changes the transmission shift points. |
12-24-2015, 06:42 AM | #3 | |
Rep 15,858
For example, in my 535i using sport mode (Drivetrain checked) and then moving the shifter to M/S, typically drops a further gear. It's as if sport mode is a half-way mode to full Sport gearbox function. HighlandPete |
12-24-2015, 07:02 AM | #4 |
Rep 1,597
Yes I've noticed this too
Current: VW Transporter Sportline, F48 X1 20i M Sport. Previous: F10 530d M Sport, W176 A200 CDI AMG Evolution, E70 X5 3.0 SD M Sport, F20 120d M Sport, E81 120d M Sport, E46 325i M Sport, E46 318ci & Many Others...
12-24-2015, 06:53 PM | #5 |
Rep 254
What about S+ vs S (drive train and chassis)? the only difference is the traction control?
C300->C63->535->S4->M4->Macan->Macan Turbo
12-24-2015, 11:14 PM | #6 |
Rep 1,698
Yes, I believe the only difference in Sport+ is that you turn off traction control.
2015 Audi R8 V10 | Brilliant Red on Black | S-Tronic | Carbon Sideblades | Carbon Trim | Full Leather | Sport Exhaust | Illuminated Doorsills | I-Pod | Contrast Stitching Previous: '14 550xi, '07 335i, '01 325i |
12-25-2015, 05:37 AM | #7 | |
Rep 15,858
If I'm in Sport mode with shifter in D and toggle to Sport+ DTC activates, no other change. If I then move the shifter to M/S the gearbox drops a cog. The gearbox dropping a further gear is not a constant, it depends on road speed/rpm, but it is clear shift points have moved up to a higher rpm due to using the M/S program. HighlandPete |
12-25-2015, 08:14 AM | #8 |
Rep 29,202
I have passive suspension so no changes there on my car, but the car feels the most sporty when both the drive mode and transmission are in sport rather than just one of them.
12-25-2015, 11:55 AM | #9 | |
Rep 254
