2010 2011 BMW 5 Series Forum F10 *UPDATE 11/10/2020**Flood Victim 550i Project :: |
10-20-2020, 07:17 PM | #1 |
Rep 2,349
**UPDATE** Got lots stripped, parts taken out! Finally getting somewhere!
Ok, so about a week ago i purchased a 2016 550i 77k miles. It had been in a pond for about 30-40 minutes *10-15 fully submerged*. Now i know what most are thinking, you're nuts! But wait a second.. Cheapest 550i i can find of this year is around $21,000.. I got it for just over 3500$.. So i know i have a bit of a road ahead of me, but heres the update so far! Previous owner never tried to start it after the pond, Once i got home, i removed the plugs and confirmed he never tried starting it. Once i removed plugs i turned it over, and spat water out of the cylinders. I then drained the oil (and 2 gallons of water) From the engine. After draining and adding fresh oil (first of many) the car will no longer crank over by the push button, Guessing its some kind of starter issue. (Motor still turns by crank quite easily with plugs removed) Todays Work! Removed all of the Computer modules from the trunk, opened up any that could be opened and cleaned all of the corrosion off (Yes i know this doesnt guarantee they will work!) And put them all back in, Then i started pulling out back steats, and stuff to get to the fuse panel in front. Parts to install: New Fuse Panels (Ordered and on the way) and.. well w/e else goes bad **LATEST UPDATE** Just wanted to share this adventure, heres a Video of the run down. Day 4************ DAY 3************ DAY 2 ********
07 E92
Jb4-G5 - Sport Exhaust - Titek BOV BBS Lm reps - AFE dual cone intake Last edited by 335iNavyGuy; 11-10-2020 at 04:01 PM.. Reason: Update / Day 2 |
10-20-2020, 08:46 PM | #2 |
Rep 452
Wow dude. You got some balls or are insane! I got balls but even I wouldn't have wanted to go down that road. Not with these kind of cars anyhow. I'm guessing fresh water since you say pond? Now I have a 535i n55 engine. The ecu which commands the start function is under my intake. Not sure where it would be on the n63. Might want to start there with getting it started. Best of luck. Subscribing. Want to see your progress
10-20-2020, 09:57 PM | #3 |
Rep 5,366
WOW!! IMHO, you'll be chasing electrical gremlins as long as you own the car.
What happened to the left rear wheel? Looks like a serious crash back there. |
10-21-2020, 08:47 AM | #4 |
Rep 2,349
Well if you watch the video you'll know! lol, it was when the tow truck pulled it out. I am an aviation electrician by trade, so i dont mind electrical issues as a whole. And i plan to take the entire interior apart and clean / grease all of the connectors, so it shouldnt be much of an issue. Also, i am replacing both fuse panels already, which i think is a huge step most miss when working on flooded vehicles. Chasing corrosion in fuses would be a neverending nightmater
07 E92
Jb4-G5 - Sport Exhaust - Titek BOV BBS Lm reps - AFE dual cone intake |
10-21-2020, 08:49 AM | #5 | |
Rep 2,349
07 E92
10-21-2020, 09:19 AM | #6 | ||
Rep 1,261
10-21-2020, 09:35 AM | #7 |
Rep 2,349
but if i get it going, ide say the headache is worth it
07 E92
10-21-2020, 09:36 AM | #8 |
Rep 1,261
Yea just hope it doesn't cost you as much as a working used one...
10-21-2020, 10:06 AM | #9 |
Rep 2,349
Well pricing everything out, i dont think it can honestly, a used running one cheapest i could find like i said was 21k, so im not sure how it can add up to anywhere near that even if the engine turned out to be bad. But i agree and i guess i get to see where it goes!
07 E92
OnlyGerman363.50 Trainwreck914132.00 |
10-21-2020, 06:30 PM | #10 |
Rep 49
This is great! I love to see people who have the guts to take this on. It will be terrific to get it going again! What a great feeling that will be.
Good luck with it all! I'm going to watch the progress. Thanks |
10-21-2020, 06:58 PM | #11 |
Rep 2,349
Your words are appreciated! Just uploaded video of Day 2!
07 E92
OnlyGerman363.50 |
10-22-2020, 12:42 PM | #13 | |
Rep 5,366
No mold... Last edited by ezaircon4jc; 10-22-2020 at 12:51 PM.. |
10-22-2020, 12:53 PM | #14 | |
Rep 2,349
Wiring harness's should be fine overall, ive pulled a few pins here and there and no rust or corrios creeped the wires. And i plan to just clean everything at this point, if i find anything BAD then i'll replace. Also if you could anymore questions please post on youtube page I could use the comments towards views lol
07 E92
10-22-2020, 08:33 PM | #15 |
Rep 452
Not sure if you'll need that d can cable. I don't use it with ista. Or esys. Only Ethernet works for me. It will do both diagnostics and coding.
OnlyGerman363.50 |
10-22-2020, 09:07 PM | #16 |
Rep 2,349
Thats what im hearing, im returning the other cable
07 E92
OnlyGerman363.50 |
10-26-2020, 07:48 AM | #18 |
Rep 452
Man water does a number on things! Good job. Can't wait for it to come to life. 🤞
OnlyGerman363.50 |
10-26-2020, 08:39 AM | #19 |
Rep 2,349
Once the new starter comes in this week, I plan to do a quick compression test, and then fire it up! (After one more oil change )
07 E92
10-26-2020, 11:26 AM | #20 |
Rep 2,591
Given how long the car was in the pond, I really doubt you'll run into serious electrical gremlins. Probably just get the typical "oops dropped my phone in the toilet" kinda problems.
2015 BMW 535xi
10-26-2020, 12:48 PM | #21 |
Rep 5,366
10-26-2020, 05:04 PM | #22 | |
Rep 2,349
Also New video up tonight, larger update!
07 E92
