08-27-2016, 08:40 AM | #1 |
Rep 69
New (used) 550i
Just dropping a quick hello. Picked up a used 13 550i M Sport a few weeks ago. Love the torque of this beast. I'm coming over from an e92 M3. So I'm having to get used to the "softness" of the suspension though I'm still impressed with how this big heavy car gets around. I threw on some Pole Position S-04s yesterday and I can't wait to excercise those this weekend.
08-27-2016, 08:48 AM | #2 |
Rep 4,209
It's considered new to most people's books. Congratulations and welcome!
08-27-2016, 08:51 AM | #3 |
Rep 891
Congratulations and welcome!!!!
Need pics
2021 MBB M5C (retired) 2018 Daytona Violet M3 ZCP (retired), 2016 AW 550i (retired) 2013 EBII 335i (retired), 2008 Platinum Bronze 535xi (retired), 2007 Monaco Blue 335i (retired) 1999 Hellrot M3 coupe (retired) |
08-27-2016, 10:48 AM | #5 |
Rep 1,589
08-27-2016, 04:52 PM | #7 |
Rep 69
It has the passive suspension. So the only thing it changes are the steering and tranny modes. Which is fine by me, I traded the M3 for a more compliant suspension and a bit more room. Though I do miss the sound of that motor, even just cruising around town. That thing sounded awesome, even with the stock exhaust.
08-28-2016, 02:10 PM | #8 |
Rep 1,254
I believe my did I could be wrong
08-30-2016, 05:56 PM | #9 |
935
Rep 4,326
Drives: M340
Welcome and lets see some pics!
2016 F10 535i xDrive - AW - Retired 2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired 2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired |
09-01-2016, 06:22 PM | #10 |
Rep 69
Thanks. I will try to post some when I get it cleaned after the rain from the upcoming hurricane blows through.
Been a blast to drive so far. Had the vibration issue, did the 60mph to 10mph thing that was suggested by some on this site on a deserted road the other night to clean the pads and rotors and its been as smooth as silk since. That right up on here saved me a bunch of time at the dealer. It has brand new brakes from the dealer so I wonder if they just never bedded them in properly. |
09-02-2016, 10:19 AM | #11 | |
Rep 736
09-02-2016, 10:59 AM | #12 |
Rep 216
Run the last 7 digits of the VIN through bmwvin dot com. BMW played games with packages every year. My '12 550i has electronic dampers but not the active suspension. If you run your VIN you'll see exactly what you have. It sounds to me like you know what you're talking about, so I'll bet you already know, but it can't hurt.
Swaybars might be a consideration... it's popular and on my to-do list. |
09-02-2016, 12:25 PM | #13 |
krrrraaauuuuut
177
Rep 524
So to the owners of the Active Suspension... which one is preferable?
I just looked up mine and realized I had the 704 Sport Suspension (passive). |
09-02-2016, 04:38 PM | #14 |
Rep 69
Zero, I had a vibration at around 55mph, then again at 65 and 70 on up to about 80. It was worse getting off the throttle at 70 and coasting. I know it's not the tires because I had new tires put on and it the vibration stayed.
Basically after a search I found a remedy from a forum member on here. So, find a nice stretch of deserted road that is straight. I found one in a commercial area where all the businesses were closed late at night. Get the car up to 60mph, brake hard to 10mph, accelerate back up to 60mph and repeat this 4 to 6 times. Then just drive around like normal. Keep I'm mind the brakes are hot after this, so they will stink and don't sit in one spot at a stop light for too long so the rotors won't warp. I only did it 4 times. I suppose it heats the brakes up enough to clean any desposits off the rotors left on them from the pads. I did it 4 or 5 days ago and the vibration hasn't returned yet. I can't remember the forum members name but it was explained it a lot better by them. |
09-02-2016, 08:09 PM | #15 | |
Rep 736
09-02-2016, 09:03 PM | #16 |
Rep 69
I just took an easy 10 min. drive back to the house. I just made sure that the first few stop lights I came to, that I left enough distance to "creep" slowly so that I never left the pads on one spot on the rotor for too long. If the rotors are fairly new and thick, its not as much a big deal as worn or thinner ones are. Thicker rotors dissipate the heat better.
