2010 2011 BMW 5 Series Forum F10 Needed - F10 non-LCI front left headlight adaptive |
11-21-2020, 06:47 PM | #1 |
Rep 4
EDIT - No longer needed - found a work-around
Hi - my driver's side headlight lost its seal and is inundated with water. I need a driver side headlight, non-LCI. Also needs to be the correct one for adaptive xenon headlights. Thank you- Last edited by lumbsplint; 12-28-2020 at 06:25 PM.. Reason: Found a solution |
11-21-2020, 08:01 PM | #2 |
Rep 1,261
12-28-2020, 06:24 PM | #3 |
Rep 4
Thanks everyone - I think I fixed my issue. No more needs.
OnlyGerman363.50 |
01-24-2021, 11:08 AM | #5 |
Rep 4
Thanks - I basically followed a few YouTube vids for removing bumper, removing headlight. I pulled it out and it quite literally drained about 6 ounces of water onto my desk. The control board was a little fried with corrosion on some contacts. I grabbed a new one off of Amazon from a non-OEM seller. Worked like a charm. Dried the headlight out inside by just letting it sit inside a warm room. I ended up running a bead of silicone all around the contact point between the lens cover and the headlight body. I then redid the electrical tape around the electrical clamps, as it had come unraveled and there was water also spilling out from the connector. So far, so good. However, I see a slight bit of condensation in the headlight this morning. I fear I didn't really fix the issue, but all is good for now.
