03-05-2021, 12:56 PM | #1 |
Rep 1,912
Metal in oil filter
In January I found out that my engine was sludged up by the original owner. After driving approximately 1500 miles I ran LM engine flush before doing another oil change and adding cera tec to help prolong the life of my abused engine.
I found this bad boy in the oil filter: The engine runs perfect and everything else is dialed in on the car but I am worried I might be stuck holding the bag when the engine goes bad. Should I part out the car and dump it or am I overreacting and I can still get a few more years out of my neglected engine? |
03-05-2021, 02:07 PM | #2 |
Rep 831
Hey Nickco43, I thought you were getting rid of your F10 anyways....
After ALL the work you put into your car, you should drive it around until the engine gives you a serious problem, then part it out...I might even be interested in some of your parts at that time....:-) Your exterior color with my interior....hmmm.... |
OnlyGerman363.50 |
03-05-2021, 03:03 PM | #3 | |
Rep 1,912
03-05-2021, 06:51 PM | #5 |
Rep 1,912
I drove the car after the oil change + cera tec and it runs better than ever. I have no idea how a sludged engine with metal shavings runs perfect.
What I am telling myself to make me feel better is that all of those metal shavings were stuck in the engine sludge and the engine cleaner flushed them all out. Unless GME goes to $10k a share I am going to drive the car until it blows up. Such a shame this engine is shot since I spent so much time and money on it. At least this was a lesson learned young. |
03-06-2021, 03:24 PM | #6 |
Rep 1,912
03-07-2021, 08:08 PM | #7 | |
Rep 1,912
03-07-2021, 09:29 PM | #8 |
Rep 831
Sorry Nick...good thing you didn't go through with the merino leather dashboard and door cards…
You might as well sell ALL your retrofits with the car....next owner might need them to feel "good" about their purchase..... If you're pissed now, don't calculate your ROI....just be happy with your Gamestop stock returns.... |
OnlyGerman363.50 |
03-07-2021, 09:43 PM | #9 | |
Rep 1,912
I want to remove my ACC parts but I can not convince myself to remove that DSC pump again. I am super happy I will be able to buy back my blue e90 that was super dialed in and sorted. It will be cheap reliable transport while I get my life started. |
03-08-2021, 06:49 AM | #10 |
Rep 188
Drives: '14 BMW 640i Gran Coupe Msport
If I were you, I would keep the car and drive it as is. You put a lot of work and money into adding all of those nice features, only to undo?
OnlyGerman363.50 |
03-08-2021, 06:58 AM | #11 |
Cole
321
Rep 498
03-08-2021, 10:03 AM | #12 |
Rep 2,591
Liqui Moly ceratec
https://products.liqui-moly.com/cera-tec-2.html Some say it's snake oil, some say it works, use your own judgement
2015 BMW 535xi
03-08-2021, 06:28 PM | #13 |
Rep 1,912
I talked to my SA today and he said they might be able to help me out putting in a new remanufactured engine. A customer recently was there for a reman engine in their X3 and it was $10,000 out the door. I wonder if BMW NA might help me out since I feel at around $8,000 it would be worth it to swap in a brand new engine.
03-08-2021, 07:00 PM | #14 | |
Rep 1,261
03-08-2021, 07:12 PM | #15 |
Rep 1,912
I will see what my SA says but I am not keeping the car without a known good engine. I am starting my life in a few months and the last thing I need is the engine to blow up when moving or on my first day of work. Now is the time to either buy back my old E90 or have the engine replaced by a dealer I 100% trust. I don't need to deal with more issues when I live in an apartment building and have no where to work on the F10.
OnlyGerman363.50 |
03-09-2021, 01:51 PM | #16 |
Rep 423
You may want to do a Blackstone Oil Analysis to see the extent of damage. Your engine could still have lots of life left.
Checkout my YouTube channel, Like and Subscribe. https://www.youtube.com/user/Gjohnson7771 MHD Flash, RVG Catless DP, RVG CP, RVG Boost Pipe, Walbro 455 LPFP, Style 433 Wheels, BC Coilovers, Ebay Strut bar, M-Sport Front Conversion, RVG FMIC, 6WB Cluster. |
03-09-2021, 02:12 PM | #17 |
Rep 658
I second this. Clearly the engine was neglected but now having done a flush and oil change, the oil that's in there right now would be a better determinator of the engine's life. Your air mass and pressure faults have nothing to do with the mechanical engine internals, so worth the $30/$40 to test the oil.
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24 |
OnlyGerman363.50 |
03-09-2021, 02:23 PM | #18 | |
Rep 1,261
03-09-2021, 05:12 PM | #19 | |
Rep 1,912
In terms of financials I am 20k into the car. I suspect the value of the car as it sits is about $10k with all of my retrofits taken off. I can take out my 6wb, nbt evo, wheels and all of the other bits I put on the car and sell them for 4-5k which would mean I am taking a $5,000 loss. If the engine does pop the car is only worth about $3-4k leaving me with about a $12,000 loss. 2011 N55 cars have rod bearing issues even when they are taken care of. Mine has been abused. Let's say that the car lasts another two years as it sits. Every single day I would worry if today is this pos engine's last day and leaves me stranded somewhere. Not to mention I am a bit picky and would be rushed to find a replacement vehicle and who knows if this used car crisis would be over by then. The opportunity to buy back my old E90 which is a known good car for the same $4,000 price that I sold it to the guy is hard to pass up. At the same time with the help of the FCP euro lifetime warranty, GME, $100 an hour labor rate at my rural PA dealership, my 25-30% discount with the dealership parts manager and *maybe* BMW NA's blessing me by helping me out on the engine replacement costs I can get the engine replacement cost down enough so it would be worth having a brand new remanufactured engine that will last me for many years to come so I can enjoy all of the hard work I put into my F10 without worry. |
03-09-2021, 05:41 PM | #20 | |
Rep 2,591
2015 BMW 535xi
03-09-2021, 06:23 PM | #21 |
Rep 1,912
03-10-2021, 06:19 AM | #22 | |
Rep 1,873
The Internet amplifies everything bad, and failure threads get copied everywhere in circles with "ANOTHER 2011!!!!". A long time ago I used to regularly do Blackstone analysis. I've started up again, and informed them exactly what material is found in the rod bearings. No signs of any issues, including rod bearings, on my 2011 so far. TBH, I am probably more concerned to watch for fuel, coolant and shearing out of grade than bearing material but obviously if any metals show up I need to know. Coolant and oil can mix in my OFH design, fuel injector failures and short COVID trips can cause a lot of fuel dilution etc... |
OnlyGerman363.50 95blkmax212.50 |
