2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Oxygen Sensor error
      03-15-2021, 03:00 PM   #1
womey31269
Drives: BMW 520D
Oxygen Sensor error
Hi, I have a problem that is driving me crazy with the "oxygen sensor". I had this 3 error codes: 284E00 283400 282E00, normally I just delete them and appear again when car does DPF regen.
Today I changed the lambda that's under the car, after the dpf, as I read that this error codes are related with that specific lambda (car has 3 or 4 of them).
Now it throws another error that I can't find on Google, 285400 and I don't know why, and I'm kinda sure that will throw more errors when a dpf region will occur.
Here are some photos of the error and some more info:
Anybody has some idea about what is happening? And I'm almost 100% sure that more errors will show up when the car will do the first dpf regen.
Thank you!
      03-24-2021, 05:56 PM   #2
womey31269
Drives: BMW 520D
nobody?
      03-24-2021, 07:45 PM   #3
chipguy
Drives: 12 528i
I will give it a try. Seems like you have an intermittent problem. Frequency is 18 while the healing counter is 40. I believe that means sometimes the fault is there and sometimes it is not.
I would clean the pins inside the connectors for that sensor. Also in ISTA, you can read the live data for that sensor.
      03-27-2021, 02:02 AM   #4
womey31269
Drives: BMW 520D
Thank you, but, what data should i look for when i check for live data?
      03-27-2021, 02:50 AM   #5
chipguy
Drives: 12 528i
This video has very good information
      04-04-2021, 12:39 AM   #6
AnotherM
Cole
Drives: 2016 m5 CP
Wouldnt "signal voltage too high" also mean the car is running too rich beyond the point the DME can compensate?
