2010 2011 BMW 5 Series Forum F10 ACS springs and strut failure |
07-11-2013, 06:44 PM | #1 |
BMW Fan Boy
446
Rep 1,385
Is this common? I had a front strut fail after installing ACS springs about 3 months ago. BMW said it would not cover due to the springs, and blamed them for the failure.
Anyone else experience this? |
07-11-2013, 09:37 PM | #3 |
Long Live the 1911
46
Rep 643
Drives: Hooptie
I recall someone else on the forums having the same problem. How much is the stealership charging you for the repair?
07-11-2013, 09:50 PM | #4 |
Rep 8,801
I don't think the other person with the strut failure had any aftermarket springs on his car so I don't attribute this to ACS. Seems like a coincidence and of course the dealer is going to play the blame game.
Alan
07-11-2013, 11:25 PM | #5 |
BMW Fan Boy
446
Rep 1,385
07-11-2013, 11:26 PM | #6 |
BMW Fan Boy
446
Rep 1,385
Exactly...they were blaming the failure on the aftermarket springs. Total bullshit.
07-11-2013, 11:42 PM | #8 |
Rep 459
I had the same problem. Dealer said i had a blown strut and wouldn't cover under warranty due to aftermarket springs. Wanted 1200. I had Dinan springs so I've end up taking it to prestige. It wasn't a blown strut and everything was normal.
You sure it's a blown strut or that's that the dealer told you? |
07-12-2013, 12:47 AM | #9 |
Rep 602
I'm inclined to disagree here. Given the very nature of aftermarket springs with higher spring rates and more shock compression they often expose the shock/strut to forces it was never designed to take. Bottom line is you are playing with fire with aftermarket springs and damage caused is on the owner. Pay to play.
- 2022 X3M Comp
- 2021 X5 xDrive 40i - 2018 F80 M3 (sold) |
07-12-2013, 01:11 AM | #10 |
vroom vroom
19
Rep 134
yeah that was me, I had a strut failure before I had ACS springs put on, the shop that was doing the install asked me what I wanted to do, I said go ahead and finish the install as opposed to putting it back to stock. I just replaced that shock out of pocket last week, I have EDC so it costs more because they have to program the shock. Paid a little over a grand to replace my right rear shock.
07-12-2013, 08:18 AM | #11 |
Long Live the 1911
46
Rep 643
Drives: Hooptie
The replacement shock has to be reprogrammed??? With all these electronic parts, this car will be a money pit to keep past the warranty period. No more straight-forward replacement of parts!
When I had a buddy install my ACS springs a few weeks ago, he didn't notice anything electronic about the rear struts as with the fronts. He was thinking maybe damper control was applied to the front of the car only, but guess he was wrong. If my shocks ever go out, I might as well replace everything with coilovers and forgo damper control then. I can't feel the difference between normal and sport damper modes anyway. |
07-12-2013, 09:01 AM | #12 |
Rep 8,801
I can't imagine lowering the car 1" from the ACS springs would cause catastrophic strut failure after 1K miles. If you slammed the car 2.5"+ then the argument is much more valid. 1" is still well within normal shock operating height imo and shouldn't cause much more wear if any. Bmw has to consider that someone who drives their cars might weigh 300lbs or constantly drives with a full load of passenger in the car with stuff in the trunk. That would make even a stock suspension car drop down at least 1" ride height.
07-12-2013, 12:56 PM | #13 | |
Rep 95
07-12-2013, 01:23 PM | #14 |
Rep 751
Drives: '12 BMW AW 550xi
It's hard to blame the springs. I drove 20k+ miles with ACS springs and no problems so far. Fingers crossed
'15 Porsche Macan S / Black & Garnet Red / 20" RS Spyder Wheels / CF trim / Red Calipers / Black Rear Badge.
'12 AW 550xi / Dinan S2 / Arkym CF Spoiler / 3D Design Style Splitter / Eisenmann Race Exhaust / 20' HRE FF01 / ACS Springs / CF Grill / CF 3D Design Diffuser / Blue Calipers... |
07-12-2013, 02:45 PM | #15 |
26
Rep 195
Same here. It has also been to the dealer for a tire replacement (pothole) and they never mentioned anything about them at that time either.
07-13-2013, 12:19 PM | #16 |
Rep 1,492
The blown strut is most likely caused by the shop installing the springs. If they don't properly compress the strut, or put any inappropriate side force on the rod, it can easily damage the strut. A one inch drop will not significantly degrade strut life, so a sudden damaged strut after spring install is due to improper installation.
2020 G07 x40i BSM/Blk Merino
2022 Audi E-tron S Mythos Blk/Blk Valcona |
07-13-2013, 03:58 PM | #17 | |
BMW Fan Boy
446
Rep 1,385
07-13-2013, 05:56 PM | #18 | ||
Rep 459
Or you could put back stock springs and go in for it. |
07-13-2013, 08:04 PM | #19 |
Rep 30
I put on eibachs and within 300 miles had a rear shock completely blown out. It's the fault of the shock, not the install. The stock non-sport shocks on these cars are very close to their limit with the stock springs.
07-13-2013, 09:09 PM | #20 |
Rep 177
I drove from the Midwest to Florida with a Car top carrier a wife and two kids with my ACS springs and no problems. I just had my car inspected, tires balanced and alignment they said everything is ok. I had them check it because I'm driving to San Diego with the family sometime this month.
I did have a problem thinking the shock was bad due to the ACS Springs. But I was wrong. My front tires were out of balance and I had put too much air in the tires. |
