2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Exhaust mod - Trunk tray in the way
      09-30-2023, 09:06 AM   #1
ceka
ceka's Avatar
24
Drives: 530d 11'
Hi all,
My car comes stock with only one exhaust on left side. I installed a Meisterschaft exhaust but on the right side I had to remove plastic covers from underneath and the right trunk box.
Now I have a huge hole next to the fuse box.
What do you guys have in there that comes with double exhaust? like the 535i sport.
      09-30-2023, 02:12 PM   #2
I just went out and looked. The tray may not be as deep as yours, and I can't see anything past the muffler & heat shielding.
      09-30-2023, 08:53 PM   #3
ceka
ceka's Avatar
24
Drives: 530d 11'
I guess only solution for now is to cut original tray, shorten it and glue ir back.
Wanted an oem route but can't figure out what tray is on other cars.
      09-30-2023, 10:43 PM   #4
Just go to realoem.com & look for the tray from a 535.
      10-02-2023, 09:53 AM   #5
ceka
ceka's Avatar
24
Drives: 530d 11'
Yeah I did, and no clear shot
I guess you guys don't have the hole since it doesn't need to accommodate that large bin. Totally different setup.
no. 2 part does not cover the hole. I have part no. 1 4 and 5
      10-02-2023, 12:20 PM   #6
n3985
Drives: a car
It's easier to drill out the rivets of the plastic box then replace it entirely with new sheet metal. Then add either RTV or body sealant to the sheet and if you choose to, add sound deadening and/or black carpet to match OEM look.
ceka24.00
      10-02-2023, 05:07 PM   #7
B-Buster
Netherlands
24
Drives: F10 535i, E63 650i
Try part# 51717314089
ceka24.00
      10-12-2023, 05:48 PM   #8
ceka
ceka's Avatar
24
Drives: 530d 11'
Thanks all !
Another solution for the ones interested is to modify the existing box.
1" drop plus foam part no.1 on the bottom and part no.5 on the diagram on top as oem.
Name:  WhatsApp Image 2023-10-12 at 6.50.14 PM.jpeg
Name:  WhatsApp Image 2023-10-12 at 6.46.30 PM (2).jpeg
Name:  WhatsApp Image 2023-10-12 at 6.46.30 PM.jpeg
Name:  WhatsApp Image 2023-10-12 at 6.46.30 PM (1).jpeg
      10-12-2023, 05:52 PM   #9
Thanks all !
Attachment 3298139
Attachment 3298141
Attachment 3298140
Don't forget the heat shields underneath. There's heat under there, even if it's just a pipe & no muffler.
ceka24.00
      10-12-2023, 06:28 PM   #10
ceka
ceka's Avatar
24
Drives: 530d 11'
Yes, I believe it's pn. 51487193500.
Will install it next year with the downpipe install. Mine is a 530d 11"
Did the Meisterschaft dual mufflers on the back, no real gain in sound, guess next thing is a downpipe.
      10-12-2023, 07:17 PM   #11
n3985
Drives: a car
The heat shields underneath are two pieces.
You’ll also need 51487207270
