2010 2011 BMW 5 Series Forum F10 What's in my oil catch can? |
10-12-2023, 02:35 PM | #1 |
Rep 332
Drives: F10 535i xDrive, F25 xDrive35i
2011 535i with 109,300 miles currently. The car has virtually been problem free in the last 60,000 miles that I have owned it.
It was time to replace the leaking OFHG (block side) and I figured I will add an oil catch can because I started to see a bit of excessive oil within the charge pipe. Please see the attached photo. This is after 300 miles with an oil catch can and I have also noticed that the oil cooler gasket (which was done a few thousand miles ago) is once again leaking. I should also mention that i flushed the coolant out at the same time I did the OFHG (300ish miles). My question is, is this coolant and is it due to the leaking oil cooler gasket? |
10-12-2023, 05:16 PM | #2 |
Rep 38
That looks like the same substance that is in my OCC for the last 20k. On the N55 it doesn't really collect much oil, but I like the idea of that water not reaching my engine.
For 300miles it might be a bit excessive, but I do see a difference in it sometimes filling up quite fast and other times not so much. Due to weather conditions maybe? I'd empty the can and check back in 500 miles to see what is added. |
StradaRedlands4940.50 |
10-12-2023, 05:33 PM | #3 |
Rep 127
I think has to do with short distance driving. Engine gets hot enough, but not for enough time to allow evaporate engine internal moisture.
10-12-2023, 05:44 PM | #4 |
Rep 332
I should add that I drive a minimum of 40 miles daily (to and from work) and maybe once a week 100 miles in a day. Is that still considered short distance?
It seems like it’s condensation. I’m not entirely sure. |
10-12-2023, 09:37 PM | #5 |
Rep 2,995
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
Most likely just condensation, but with your drives, it shouldn't be that big of a deal.
So yeah, maybe coolant? When you look at your coolant, is there any oil in it? |
Houranimd49252.00 |
10-13-2023, 09:06 PM | #6 |
Rep 2,591
It's condensation mixed with a bit of oil, which forms a nice chocolate smoothie.
2015 BMW 535xi
10-13-2023, 10:41 PM | #7 |
Rep 332
Appears the consensus is condensation. I’ll take it and run. Thanks guys!
Now…someone tell me why my oil cooler gasket keeps failing prematurely… |
ChiltiCoatl891769.00 |
10-13-2023, 11:24 PM | #8 |
Rep 2,591
Make sure it's properly lubed up before install so that it doesn't tear or fold over
2015 BMW 535xi
StradaRedlands4940.50 Houranimd49252.00 |
10-14-2023, 06:10 PM | #9 |
Rep 38
What Unspec said, and make sure the bolts are torqued at the right spec. Overtightening can also cause the gasket to start leaking again. Also clean the old residue really well.
Is the gasket OEM or aftermarket brand? |
10-14-2023, 09:36 PM | #10 |
Rep 332
I only buy from fcp euro! I of course torqued correctly. I don’t dare free tighten on these finicky cars. Luckily these only take like 10 mins to swap out but I’m tired of changing it so prematurely.
10-15-2023, 10:18 AM | #11 |
Rep 127
Make sure oil filter housing and heat exchanger grooves are super clean. Assuming cylinder head surface has no burs and is flat. Next time check it with straight edge. Do you use new bolts or existing one?
Regards, |
10-15-2023, 02:20 PM | #12 |
Rep 332
I was re-using bolts, but now I think I need to purchase new ones.
10-15-2023, 04:53 PM | #13 |
Rep 127
I think using new bolts will solve leaking issue. Existing bolts are probably stretched. On the heat exchanger (#9), depends on which version you have, bolts length are different (item #10). Ask me how do I know.
10-17-2023, 05:46 PM | #14 |
Rep 2,591
New bolts will not solve the issue. The bolts are steel, but the block is aluminum. The threads in the block are what gets stretched if the bolts are overtightened. I doubt that is the cause of the leak though.
2015 BMW 535xi
10-17-2023, 10:51 PM | #15 |
Rep 2,995
Yes, I was surprised that this had steel bolts when I re-did the gaskets.
10-18-2023, 08:12 AM | #16 |
Rep 332
So what do you think is the cause of this recurrent premature gasket failure?
10-18-2023, 10:49 AM | #17 |
Rep 2,591
9 times out of 10 it's user error
2015 BMW 535xi
10-18-2023, 10:42 PM | #18 |
Rep 332
10-19-2023, 09:04 AM | #19 |
Rep 2,591
I presume you're using a torque wrench when tightening? Or just going "good and tight"?
2015 BMW 535xi
10-19-2023, 08:20 PM | #20 |
Rep 332
